headlights
Old Dec 25, 2005 | 05:25 PM
hispano1's Avatar
headlights
does anyone know how to change your headlights? b/c me and a friend tried doing it but don't know how and i read the manual and it doesn't even explain how to do it very well. If anyone can give me some tips that would be appreciated.
Old Dec 25, 2005 | 05:58 PM
clodhopper06's Avatar
i could be wrong, but i thought you werent supposed to open the headlights because of some sort of pressure or something.....idk, but i thought i read somwhere that it is only supposed to be changed by a service guy
Old Dec 26, 2005 | 08:40 AM
denniss's Avatar
Do you want to change the headlamp assembly or just the bulbs?
Headlamp Capsule, Headlamp Housing Bracket, Fog Lamp Replacement
Callout
Component Name
Notice: Refer to Fastener Notice in Cautions and Notices.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Headlamp Capsule Replacement
Bolt, Front Headlamp Capsule (Qty: 2)
Tip
Remove the inner upper grille fascia push-pin.
Pull the lamp forward until the lamp disengages from the lower bracket.
Push the lower inside corner of the headlamp inboard until the outer lens releases from under the outer fender flange.
Rock the headlamp composite side to side and pull outward.
Disconnect the electrical connector.
Tighten 10 Nˇm (89 lb in)
Bulbs, Headlamp
Caution: Refer to Halogen Bulb Caution in Cautions and Notices.
Tip Rotate the bulb/socket counterclockwise to remove from the capsule.
Headlamp Housing Bracket Replacement
Bolt, Headlamp Housing Bracket (Qty: 4)
Bracket, Headlamp housing
Bulb/Socket, Fog Lamp
Tip
• Disconnect the electrical.
• Rotate the bulb/socket counterclockwise to remove from the fog lamp.
• The fog lamp bulb/socket can be replaced, without removing the fog lamp.
Lamp, Fog
Tip
• Disconnect the electrical connector from the fog lamp bulb/socket.
• Release the fog lamp from the front fascia.
Old Oct 4, 2006 | 03:12 PM
hackeragent061's Avatar
it takes forever to get them out the first time and u don't have to mess with the pins from the grille
Old Oct 4, 2006 | 03:13 PM
xspyder85x's Avatar
its just 2 bolts, you have to wiggle them out, good luck
Pasierbek
Dec 10, 2015 07:22 PM
allpro666
Oct 6, 2015 08:11 PM
brickloaf
Sep 21, 2015 02:17 PM
jonnycat
Sep 19, 2015 12:58 PM
