headlights not bright enough
So I bought my Ss/tc about a month ago. Some things have been done to it to include the headlights. They are gen 4 with xentec hids. What hids do I need to get for them to be brighter. The black box says voltage on them is 35. Do I need to get a stronger kit?
Your best buy is gonna be to buy/make a set of retrofits. They will have a brighter beam and a much wider one. You can run a 55w hid setup, but there's a high risk that you will damage the chrome on the reflector bowls of your current projectors, which will make the output even worse
Also do you know what color temp the current bulbs are? Whiter bulbs would help, and I'd they are more than a year old you'll gain a lot of light by simply replacing them with new bulbs. Hids dim over time, and aftermarket bulbs tend to have a very short lifespan
tey are not a slight bit water resistant and have a huge ballast failure rate.and the gen 4s take h7 bulbs
If you want a good, high quality set of bulbs, then get these
H7: Morimoto 3Five - HID Bulbs from The Retrofit Source Inc
brickloaf
Sep 21, 2015 02:17 PM
