headlights are in the oven, important question!
alright my headlights are now in the oven baking for 20 min at 200 degrees...
when im ready to paint them black, WILL IT AFFECT light output if i paint the ribbed part black?
someone with that part painted black please chime in!
Just don't paint the turn signal area (the bowl of rectangles). The ribbed area is for her pleasure....er,... I mean it won't be effected at all. When you remove the bezel, the reflector for the hi/lo beam is a separate part
alright thats the answer i needed
ahh no more stressin.. thanks guys
one more thing tho my car is black should i paint my housing flat black, satin black, or gloss black? and gestapoo, did you sand the housings before u painted them?
Last edited by 08ShowbaltLS; Apr 18, 2010 at 08:25 PM. Reason: Automerged Doublepost
scuff them up somehow. Dont have to do anything rediculously crazy as they wont see wear and tear. nothing will ever touch the insides again after there painted. But as a general rule yes scuff them up. Use a scotch bright, or if you want the back of a sponge that green part will suffice for this. Idealy if you have any adhesion promoter spray it since its a plastic part but like i said before it shouldnt really matter. theyll never bend or flex or see sponges and soap or rocks or anything. And paint gloss black. Matt black looks like plastic, make it look better then that
thanks bud! and good luck, its easy youll do fine. when you spray make sure your 1st coat is a fine mist. dont try to cover it on the 1st coat, i will gaurantee a fish eye.
lmao this! make sure your oven wasnt bought on Ebay
update.
got the lense off and damn was it annoying anyway got the headlight painted with krylon fusion gloss black and it looks absolutely amazing, not a smudge or hair on any of them
thanx everyone for the help. you guys make css.net actually look sorta helpful sometimes...
I wouldn't even bother with gn 1's. too much bitch work.
