Help!!
Help!!
Ok someone who has taken there spoiler off b4 help me out...Ive ot the bolts all off and it seems there is a **** load of adhesive underneith so what do i do now?? Ive tried a heat gun and fishing line but it seems to be failing. HEEEEEEELP
You Might want to try: Peeling as much as Possible! Then A Clay Bar & Some Clear Coat safe Scratch Out! Should do the Trick & U can Buy at any Automotive store & Some Walmarts1
Mequiar's Clay Set & 3M Scratch Remover.
Oh & NO More Heat only makes it Harder!
ok so heat is out lol. what exactly do you mean by peeling?? im confused...
Means be very carefull Not to scratch the paint & Use razor to remove the top layer or try to do it with your finger nail! Then use Scratch out & clay bar!
Would help to see some Pics!
well my trouble now is i have the bolts off but im trying to seperate the wing from the trunk itself lol. I can't use my nail to peel anything cuz i can't get the bloody thing to wiggle off.
OH I thought you where talking about whats Left after removal my bad!
This is what i did, I removed the bolts and yes this can get very messy... Lay some cardboard down get your G/F's hair dryer and heat up the underside of the spoiler with it, Try and get close to the metal and then try and GENTLY pull up a little bit and if you maage to get any up get some goo gone in the crevis and go back at it with the hair dryer untill she comes soo very smooth operation the glue was the hardest part to get off.. Good luck let us know how it goes.
