Help
Old Dec 5, 2006 | 07:07 PM
italstalnprd86's Avatar
Help
Anyone got some suggestions on what i need to pollish the valve cover? I see blilbt's, and i like it a lot, bro can you give me some suggestions, i have all the time in the world, just need to know what to use. Im pretty sure some sort of buffing wheel is involved, most likely on a bench grinder, but how bout those scuff pad type things that are twist-lock and go on the pnuematic air grinder? Someone help me out with this because i have heard many different things.....
Old Dec 6, 2006 | 01:26 AM
um no one knows anything about this??????
Old Dec 6, 2006 | 12:06 PM
biohazard's Avatar
Get low
i just wet sanded with a bunch of diff grits, takes about 6 hours..... there is a more eficient way with a die grinder but idk the specifics
Old Dec 6, 2006 | 01:58 PM
rally's Avatar
I didnt even wet sand, just goto walmart (or wherever you get your sand paper) and grab a couple sheets of each from 200 to 2000. Sand with each, rinse excess, repeat until you think its done.
When your done sanding grab some metal polish cream. (I used Maquires) and rub it in, wipe excess. And your done.
Old Dec 7, 2006 | 12:21 AM
vaacoustic's Avatar
I've been looking into this alot as well. Here is a website I found (yeah....Ford guys know something useful here!) that shows a nice little bit. Check it out.
http://www.superstallions.com/tech/carcare/polish.html
Old Dec 8, 2006 | 01:58 AM
thanks vaacoustic looks very good i will be reading that this eve!
