Help B4 I mess it up....VHT / blackouts: how to make it shine
Ok,
So I have been getting hell from you guys and my ls1tech guys.
My tails not as smooth/shiny as they should be so what do I do?
What I did:
4 coats VHT with sanding between coats
3 coats clear
sanded
polished
wax
still, look for yourself.
Without re-doing it, what do you guys recommend I do?
I have heard, "just polish them," "wet sand them," "rubbing compound"
etc
etc
I am at your mercy
What I did:
3 coats clear
sanded
polished
wax
etc
etc
I am at your mercy
I found that putting on a heavier coat helps to make the nice and shiny. Mine looked like yours on my first attempt doing it the same way. I then did it the quick and dirty way and had a lot better results. I simply prepped the lights with some light wet sanding and then gave them several heavy coats of VHT w/o sanding them between coats. Then added several clear coats followed by wax and they look 10X better.
I sanded it down to remove the clear.
re-applied 2 coats of VHT.
They are already smooth and shiny now but I am going to throws some clear on and polish.
that should do it.
will post results.
thanx guys
i used duplicolor clear
that should do it.
will post results.
thanx guys
Nice wet coats are important, if you get a light coat on there it dry to quick, and doesnt flow out. I dont even have clear on my 3rd brake light, and(no offense) it looks MUCH better than your tails.
