Help With Projectors.
So I bought the 1st generation projectors on ebay and tried to install them tonight. I cut the black wire, which I think is the ground wire for the stock headlights and the brown wire to hook up the leds and halos. However, I need to get these connected as I lost my gauge cluster lights and tail lights. Brake lights work fine. If you can help me and you live in Maryland or Northern Virginia, I am willing to drive and pay a small fee tomorrow. I'll be available tomorrow afternoon around 1 or so and definitely won't mind your help.
Call or text me if interested or post.
301 266 9518
Update: I have tail lights and gauge cluster lights. I went to hook up the leds and halos and the top 3 leds work but the 4 halos don't.
301 266 9518
301 splits into 97 eventually I think. It's mostly southern parts of Maryland. I live in southern Maryland and I know exactly where Glen Burnie is. Big street racing town.
301 266 9518
301 266 9518
Yeah, I know, the thing is, I don't have any electrical experience and I need A LOT of help with this. I'd much rather pay someone and have them do it for me. The HIDs are beautiful. I don't have the tools necessary for connecting the wires.
I have the black and brown wires twisted to each other right now. So they look like a stock harness. I don't understand why I lost my taillights and gauge cluster lights though.
Check Your Fuses !!!!!!
post a pic of what the ligth and all the wiring looks like and i might be able to walk you through it or pm the pics and i'll take a look. i just finished wiring up my hids to my stockers so its still pretty familar lol
Fuses Usage
SPARES Spares
Blank Not Used
Blank Not Used
REAR DEFOG Rear Defogger
COOL FAN2 Engine Cooling Fan High Speed
CRNK Starter
COOL FAN 1 Engine Cooling Fan Low Speed
BCM3 Body Control Module 3
BCM2 Body Control Module 2
FOG LAMP Fog Lamps
HORN Horn
RT HI BEAM Passenger’s Side High Beam
LT HI BEAM Driver’s Side High Beam
RT LO BEAM Passenger’s Side Low Beam
LT LO BEAM Driver’s Side Low Beam
DRL Daytime Running Lamps
FUEL PUMP Fuel Pump
EXH Exhaust Emissions
Blank Not Used
Fuses Usage
INJ Injectors
Blank Not Used
ABS Anti-lock Brake System
PCM/ECM Powertrain Control Module/Engine
Control Module
EPS Electric Power Steering
AIR PUMP AIR Pump
PRK LAMP Park Lamps
WPR Windshield Wiper
IP IGN Ignition
A/C CLTCH Air Conditioning Clutch
AIR SOL/
AFTERCOOL AIR Solenoid (L61, LE5),
Aftercooler (L4)
ABS2 Anti-lock Brake System 2
PRK/NEUT Park, Neutral
ECM/TRANS Engine Control Module, Transaxle
BCK UP Back-Up Lamps
TRUNK/OUTLET Trunk, Accessory Power Outlet
Blank Not Used
Blank Not Used
S
BAND/ONSTAR Audio, OnStar
Ž
ABS3 Anti-lock Brake System 3
LTR Cigarette Lighter
MIR Mirrors
HTD SEATS Heated Seats
CNSTR VENT Canister Vent
Relays Usage
COOL FAN2 Engine Cooling Fan 2
WPR HI/LO Windshield Wiper High/Low Speed
CRNK Starter
COOL FAN1 Engine Cooling Fan 1
FUEL PUMP Fuel Pump
WPR ON/OFF Windshield Wiper On/Off
COOL FANS Engine Cooling Fans
PWR/TRN Powertrain
AIR PUMP AIR Pump
AIR SOL/
Aftercooler (L4)
RUN/CRNK Run, Crank
Misc. Usage
PLR Fuse Puller
1 Fuse Puller
2 Empty
3 Empty
4 Empty
5 Empty
6 Amplifier
9 Stoplamp
10 Heating, Ventilation, Air
Conditioning, PASS-KeyŽ III+
11 Empty
12 Spare
13 Airbag
14 Spare
15 Windshield Wiper
16 Climate Control System, Ignition
17 Empty
18 Empty
19 Electric Power Steering, Steering
Wheel Control
20 Sunroof
21 Spare
22 Empty
23 Audio System
24 Sensing and Diagnostic Module
(Airbag)
25 Engine Control Module, Transaxle
Control Module
26 Door Locks
27 Interior Lights
28 Steering Wheel Control Illumination
29 Power Windows
Relays Usage
30 Climate Control System
31 Empty
32 Retained Accessory Power (RAP)
7 Cluster
8 Ignition Switch, PASS-KeyŽ III+
Any clue what it could be? I don't think the ambers light up either when I start up the car with the remote key.
SPARES Spares
Blank Not Used
Blank Not Used
CRNK Starter
FOG LAMP Fog Lamps
HORN Horn
FUEL PUMP Fuel Pump
Blank Not Used
Fuses Usage
INJ Injectors
Blank Not Used
Control Module
AIR PUMP AIR Pump
PRK LAMP Park Lamps
IP IGN Ignition
AIR SOL/
Aftercooler (L4)
Blank Not Used
Blank Not Used
S
Ž
MIR Mirrors
Relays Usage
CRNK Starter
FUEL PUMP Fuel Pump
PWR/TRN Powertrain
AIR PUMP AIR Pump
AIR SOL/
Aftercooler (L4)
RUN/CRNK Run, Crank
Misc. Usage
PLR Fuse Puller
1 Fuse Puller
2 Empty
3 Empty
4 Empty
5 Empty
6 Amplifier
9 Stoplamp
11 Empty
12 Spare
13 Airbag
14 Spare
15 Windshield Wiper
17 Empty
18 Empty
Wheel Control
20 Sunroof
21 Spare
22 Empty
23 Audio System
(Airbag)
Control Module
26 Door Locks
27 Interior Lights
29 Power Windows
Relays Usage
31 Empty
7 Cluster
oh my god dude......... message me now on msn or aim
aim is saunders1986
msn is sam_saunders17@hotmail.com
i'll walk u though it.
aim is saunders1986
9 and 7 didn't do anything. I tried both of those before even reading this. Come to find out, I remember my ambers didn't light up when I remote started the car and they did with the stockers. So, I checked the parking light fuse and sure enough, my gauge cluster light and taillights are back to life. Who would have thought that the parking lamps would have done the job?
Thanks. However, I think the fuse blew was because of the car being in the on position. Don't ask. I honestly wasn't thinking. I have my driver side brown and black wires back together respectively with electrical tape for now and I'm going to hook up my leds and halos (with the car off) as soon as I get off work.
Okay so I followed the how-to and my top three leds work, however all four halos don't work.
Anyone know what the problem could be?
