Hid Headlight questiom???????
I have the third gen projector headlights and I was wondering if I could put a HID conversion kit in them with out having any problems? Has anybody done this and if so how is it working?
Order the bulbs for the SOCKET of the HOUSING. The projectors use H1 bulbs... so ordering a 9007 kit won't fit. THe 9007 kit should only be ordered if you're using them in the stock housing.
Order the H1 harness. The battery fed harness hooks into the wiring of the housing's headlight socket for the remote turn on wire... meaning the 9007 isn't compatable. Trust me, I've made this mistake and had to order a H7 plug to splice in place of the 9007 one.
but do u need a relay or anything, it says for cobalts 07 and up, and i had 9007 hids for two years in stock housing and it was pretty much fine........but idk why it says u might need that relay..
1) The ballast for the HIDs. This should come with the HID kit. It's basically a transformer that ups the voltage from the car's standard voltage to what the HID operates at.
2) The daylight running light relay. This is only needed for cars that use their headlights (not front yellow running lights) for their DRLs. The reason for this is that the car operates the DRLs at a lower voltage than full headlight voltage. This is bad for the HIDs because the ballast then can't up the voltage to what's required for the HIDs.
The quick answer version to your question is I don't remember if the '07s used the headlights as DRLs, but if they do, then you'll need the DRL relay for your HIDs. If they don't then nothing's needed and you're good to go.
I'm not sure for the 07's because their DRL's mess with the HID's. I have an 06 and I did not need the relay. Just the plug and play kit and I was set to go.
ive had hid's in my 07 for a while with no relay ,everyything works fine, and i am pretty sure i do NOT have daytime running lights which is weird since i see evvery othe r cobalt during the day with them but not mine and im an 07..
so i asked that question tho because i have projectors now and im going to order the h1 bulbs with a 9007 harness correct? and i know i dnt need the relay now..
To the OP: I forgot about this option. You could just pull your DRL fuse in the fuse box too. It should be in the upper left-ish part of the fuse box by a big relay if you're standing in front of the car.
The relay harness is reccommended... but you can run without it unless you encounter issues or want to use DRL. If you're going to not use the harness on the 07+, yank the DRL fuse under the hood. You will only lose DRL function, not the autolamps (Your lights will come on automatically at night or when raining).
As far as modification to the 3rd gen housing, you will need to perform the anti-glare mod (See how-to section) to remove those bright spots that occur in them. Other than that, you don't need to do anything to them as far as bulb sockets go. The return lead will be a little tight when putting it in, but i'll not hurt anything.
It's great if you're like me and want to go cheap to see if you like them as-is, but then may decide later that you want HIDs after all.
