HID installs in projector help
has Anyone installed the HIDs in the projector housings? I picked up the 8000K bulb kit from vision. On their website they recommend connecting the relay harness to the battery. Since the battery is in the trunk on these cars, how is this accomplished?
Also does anyone know if you have to re-aim the headlights after installing the HIDs if the projectors were aimed properly with stock H1's that come with it.
umm you shouldnt need to adjust the proectors but you might be blinding the hell out of peole soo aiming them a lil down might be good, annd hook it up somewere in the fuse and relay panel under the hood you have plently of battery Hot leads in there
and heres a vid to help you understand the relay wiring.
http://www.youtube.com/watch?v=LbJxdhaWJnk
Your battery is wired all the way to your engine bay in the form of your "boost terminal" which is hidden under a red cap on your fuse box.
its a perfect place to wire your relay. it takes some elbow grease to crack it loose, but it will loosen, then you can just slip your connector in there and tighten and voila.
those two, you have to cut and splice them into the wiring harness to the lights... word to the wise make sure you have the right positive hooked up... one is brights, on isn't lol..
I think it's the orange you have to use if I remember correctly.... haha.. plug and play my ass
the main headlight harnes.. cut the connector off that goes to the stock headligh bulb (not the harness from the car to the headlight, but the one that goes to the back of the light.
black to black./.. white to orange... and you are done (you don't have a high low kit right?
If anything I"ll take pics of my setup when I get home tonight (HID headlights and fogs)
Last edited by 06blackg85ss; Mar 14, 2007 at 04:42 PM. Reason: Automerged Doublepost
hes right.
imagine that like your "switch"
you wire that into the power/ground of your old lowbeam headlight wires.
by doing that, when your car turns its lowbeams on, your relay recieves a signal, telling it to allow your HIDs to begin drawing power through the larger gauge wires that you have wired to your battery power
left beam
right beam
both (yes i know they are not even)
the void
I also have a problem with mine... I only have 1 beam hitting the road. I posted a thread on it in the problems/service section. That black hole seems like the way it would be stock...--- except AMPLIFIED! That's all I know.
we seem to be getting closer to the answer, see page 4 of this thread
https://www.cobaltss.net/forums/showthread.php?t=44181
when I get mine resolved, I'll be sure to post resolution with photos.
I don't believe so, If you look at the photos i posted on page one of this thread you will notice the little "z" at the top of the cutoff of the beam. That z is the center of the beam, which is clearly aimed directly in front of my car. On a side note, my passanger side is aimed a bit too high, the z's should be on an even plane.
I have this problem as well. I thought they were pointed too far to the left and right, and pointed them in, and it didn't help. IMO the projector lenses simply aren't set up to handle HID, maybe the length of the HID bulb vs. the stock bulb, or maybe just more light output. If someone has a solution I would be elated.
If you didnt modify your projector housing to fit the HID Return lead. dont be surprised if your HIDs dont work worth a ****.
You have to make room for that return lead or it doesnt allow the bulb to sit straight in the housing, and therefore gives you a **** light pattern.
