hooking up HIDs
Old Nov 12, 2014 | 11:38 AM
GreenySC2's Avatar
hooking up HIDs
So ECaulk recently sent me back my lights looking amazing, but going through everything for hooking them up isn't there supposed to be a plug for the original plugs(you know the ones to the bulb) to plug in? I'm not finding anything......
all I have is this blue plug that's unaccounted for.... anyone?
Old Nov 12, 2014 | 11:40 AM
blueLNFftw's Avatar
It plugs into the headlight.
I can see the other end in the background...
Old Nov 12, 2014 | 11:42 AM
GreenySC2's Avatar
but there is only one blue plug and the harness goes to both headlights....
no instructions I'm super lost
Old Nov 12, 2014 | 12:57 PM
UnkleRaRa's Avatar
I know when I hooked Lumens HID kit up, I only had to connect certain plugs to one headlight, and just the relay to the other one.
I think its normal, but not knowing anything about the setup, im not too sure.
Is it a Bi-Xenon setup?
Check here for instructions. Maybe one of the setups is the same and will work: Lumens Xenon HID Installation Instructions, Help and Hints
Old Nov 12, 2014 | 01:30 PM
Well if you got your harness you only need to connect the drivers side and leave the passenger unplugged
Old Nov 12, 2014 | 01:47 PM
GreenySC2's Avatar
ahhh gotcha that kinda makes sense
Old Nov 12, 2014 | 02:04 PM
Yup and to the harness connect the ballast and get your ground and that should be it get your power from the battery terminal under the hood. Well thats what i did
Old Nov 12, 2014 | 05:25 PM
That harness only needs signal from one headlight (just replied to your text sorry man clients on site and running a breaking down pilot plant).
I forget how complicated the harness is the first time, you need to ground both ballasts. I'll snag pics of the grounding locations I use, and as eddieavila10 said one hooks to battery should be marked with a + on the little plastic tag unless UPS shipping knocked it off
Old Nov 12, 2014 | 05:44 PM
Well for me it was a red wire so it was pretty straight forward. Lol and trust me at the beginning i was confused but after looking at it i got it
Old Nov 12, 2014 | 07:12 PM
GreenySC2's Avatar
there are three that say battery? I'll look closer tomorrow hah
chefhhr
Oct 26, 2015 10:36 PM
jcalvin1126
Oct 26, 2015 12:31 AM
allpro666
Oct 6, 2015 08:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
dieGone
Sep 23, 2015 10:20 AM
