how to do eyelids?
Old Jul 29, 2006 | 12:57 AM
hardtocope's Avatar
how to do eyelids?
i was thinking about getting some eyelids for my car. i have a red cobalt so i was thinking about getting black eyelids?? does anyone know if i could tint my headlights using regular window tint?
Old Jul 29, 2006 | 01:32 AM
JimmiLS05's Avatar
I dont' know how well the tint would hold up inside or outside of the lense. What about just taping off a section of the light and using NightShades instead? Otherwise they're made out of vinyl so far.
Old Jul 30, 2006 | 08:49 AM
mcphatty's Avatar
dont use tint- its not designed to be on the outside of the car. besides, have fun trying to get that tint wrapped around our lights. use some vinyl, its much easier to work with and it will last longer.
Old Jul 30, 2006 | 10:17 AM
stg2cobalt's Avatar
yep i keep telling you my friend use vinyl much easier and cheap
Old Jul 30, 2006 | 11:21 AM
hardtocope's Avatar
does vinyl leave residue?
Old Jul 30, 2006 | 11:52 AM
biohazard's Avatar
Get low
no but for black just use nightshades... trust me i had vinyal cf ones it looked good but idk there are always tiny bubbles
Old Jul 30, 2006 | 12:20 PM
stg2cobalt's Avatar
the bubbles is bc you did not instaled them right
stg2cobalt's Avatar
Old Jul 30, 2006 | 09:53 PM
mcphatty's Avatar
yea mine didnt have bubbles either- just make sure you use hot soapy water (dish soap works fine) and spray both the surface of the headlight (clean it first) and the back of the vinyl sheet. it makes it easier to install, then just use a squeegee to get all the water out from under the vinyl and let it dry. i use my drivers license as a squeegee, and a hair dryer to quicken up the drying process.
Old Jul 30, 2006 | 10:01 PM
biniecki's Avatar
thats how the pros do it. I use to work at a vinyl shop.
Old Jul 31, 2006 | 11:16 AM
4drssmikekc's Avatar
does anyone have a patern they used? stg2cobalt yours look sweet, probably the best Ive seen.
Old Jul 31, 2006 | 12:29 PM
stg2cobalt's Avatar
if you pm me your address and what color you need i can send yo a pair of eyelids
thank for the compliment
Old Aug 4, 2006 | 03:30 PM
so does anyone have template or anything help as far as what they used as a guide when doing there eyelids?
Old Aug 4, 2006 | 05:44 PM
stg2cobalt's Avatar
one word:
imagination!!!!
Old Aug 4, 2006 | 06:06 PM
tiny's Avatar
niteshades is the easiest way to do them
but if you wanna use vinyl, use masking tape to layout your line, and then cut the vinyl
Old Aug 8, 2006 | 04:59 PM
Originally Posted by stg2cobalt
one word:
imagination!!!!
hey thanks, your a big help.
what happened to
"if you pm me your address and what color you need i can send yo a pair of eyelids
thank for the compliment"
Old Aug 8, 2006 | 11:10 PM
06LSjunkie's Avatar
wat do you use to make the vinyl stick?
Old Aug 9, 2006 | 12:55 AM
mcphatty's Avatar
it has an adhesive on the back. its like a rubber sticker
Old Aug 9, 2006 | 01:21 PM
stg2cobalt's Avatar
what happened to
i totally forgot about that man i think i even delete you masage please pm you address
Old Aug 9, 2006 | 02:16 PM
sent
thanks
Old Aug 9, 2006 | 04:53 PM
06LSjunkie's Avatar
thanks mcphatty
Old Aug 9, 2006 | 06:11 PM
mcphatty's Avatar
just whatever you do- DO NOT cut the vinyl while its applied to the headlight. it'll look fine until you go and remove the vinyl, leaving behind a nice score the shape of your eyelid
Old Aug 9, 2006 | 06:30 PM
cblt12's Avatar
i used paint for mine and figured some paint thinner would do the trick if i didnt like them but i still like them so i never had to figure that out
Old Aug 12, 2006 | 09:14 PM
mcphatty's Avatar
i believe paint thinner will also dissolve the plastic.. not straight through it, but enough to fog the lenses up
Old Aug 13, 2006 | 11:22 AM
Karla's Avatar
no it wont. mine were painted and had to take it off to put primer first cuz it was too much see threw. paint thinner was used and did not do anything but "thin the paint" hence the name paint thinner. i love my eyelids. they make my car look mean as hell.
