How hard is it to learn to paint?
Somebody scratched the shit out of my rear lip and bumper, and I don't want to pay a body shop to fix it. I am considering tackling this myself and was wondering if anybody had any advice. I also have a few questions.
How hard is it to get the paint to match? I was just going to order GM victory red paint. What kind of primer and clear coat should be used? If I take my time do you think I can get it to match? I've done some research on the process and it looks like something I can handle but is it reasonable for me to think this is something I can do on my own? |
Originally Posted by ddawg23213
(Post 6761787)
Its not gonna cost that much for a shop to fix it if its just scratch maybe $200-$300 or even less depending on the shop. Spray Can will look terrible.
It's multiple scratches and possible even very light gauges that need to be filled which I can do. I have parts to practice on, and I am mechanically inclined.
I wasn't going to rattle can it, I have a spray gun, compressor, and an air dryer. What are these special tools that they have to do the job? |
(Post 6761787)
How hard is it to get the paint to match? I was just going to order GM victory red paint. What kind of primer and clear coat should be used? If I take my time do you think I can get it to match? I've done some research on the process and it looks like something I can handle but is it reasonable for me to think this is something I can do on my own? sandpaper, 320, and 600 grit, paint, can get it off your paint code in the trunk and take it to a paint store for the right color reducer for the paint primer sealer high build primer thinner for the primer clear coat hardner for the clearcoat wax and grease remover all that you can get at a paint store, but will cost you about 2-300 bucks cause they dont make it in small quanties. But its a good thing to have if you want to do more painting their are two ways to do this, 1 mask off the car around the bumper, or take the bumper off, if your limited on space, pull the bumper off and spray it, but make sure if you pull it off, you set it up so like its sitting on the car, the color will match better. once you have the bumper off, sand it down with some 320 and get it nice and smooth, and knock off as much paint as you can, spray on the high build primer after mixing it to the proper mix, take some paint of any color and mist it on the bumper, this is a guide coat, now you can start block sanding everything out with 320. and get as much of the guide coat off that you can. once your done with that and are happy with how smooth it is, its now time to seal it with the primer sealer, than hit it with some 600 grit, and clean it all off with the wax and grease remover, than spray the color, once its dry, spray the clear, let it dry, mount on your car, and enjoy |
so you would recommend spraying the paint with the part on the car?
Is there anywhere online where I can get this stuff in smaller quantities? I am trying to keep the cost down. |
(Post 6761863)
i was mainly refering to a booth.... however sounds like you may have a good grasp of what needs to happen so maybe your results maybe better then most.... just make sure its warm and dust free and it has chance....
I think there's a learning curve to.painting, from my experience. I picked it up rather quickly, however I did a lot of research and emailed a few people for advice. My best suggestion if you want to get a good idea of what's entailed. Look up swrnc on YouTube. His names Pete and he does videos about building hot rods and autobody. He has a channel directed straight toward the layman doing autobody repair at home and he covers blendong and prepping and the whole 9 yards. Its called diyautobody or something similar. He is always happy to answer questions via email and even sometimes by phone. He is a little rough around the edges and cusses a lot in his bids but is a pro and helped me out a lot when I painted my bike, which was the first thing I'd ever painted that wasn't rattle can. And Brian ollson seems to be pointing you in the right direction. But like I said check out Pete on YouTube, you cannot go wrong there.
TCP Global - Quality & Service Since 1974 sells paint online and you can buy quart kits. I believe they even color match from yourVin, however ppant stores don't always get the color mixed right and if it was off that would be a big hassle to return.
(Post 6761828)
yeah, the paint itself isn't too expensive, all youd' really need is half a pint, be about 30 bucks, but the reducers and other stuff is what starts running up the costs, cause you can usually only get them in half gallons and their about 60 bucks, for the primer, you can get away with spray can primer to cut the costs, it wouldn't look totally perfect to the perfectinst, but honestly you take your time with it and do some really good prep work, and you honestly won't even notice
6 Attachment(s)
Attachment 50835
Attachment 50836 Attachment 50837 Attachment 50838 Attachment 50839 Attachment 50840 This is a valvecover I did for a friend using spray can primer, auto paint color matched, and spray can primer, I think it turned out pretty well, and it matched the car perfectly |
2 Attachment(s)
Attachment 50833
My first ever paint job using a hvlp gun not bad for using a $50 harbor freight gun if I do say so myself! Paint was hok tangerine candy, even though the camera couldn't pick up the color right. Attachment 50834 This is after I wrecked her :'( my Kodak can shows the color much better. |
Originally Posted by joezombies
(Post 6762099)
What size of air compressor do you have?
(Post 6762318)
I think it's around a 20 gallon
lol ur ass is crazy pay the money and call it a day
(Post 6762371)
ya but im a professionallist and sorta like my paint to last. Shit is rough to come out looking good with a good both when u know what your doing. When u dont and ur just spraying it who knows where... god damn
(Post 6762399)
but painting is not hard at all, its all in the prep work, and all paint can last, just depends on how you take care of it after you paint it. |
yeah theres a knack to painting, experiment first on a large piece you dont care about, if you have a buddy with a shitbox tell him you'll paint his door or somthing if he pays for paint.
a guy in my local club got an SS bumper and painted it himself.. and trust me... he didn't have to tell us he painted it himself :r: |
Well done rght anyone could paint a car. Ya'll talk like what you buy from a paint supplier is completely different from what paint shops use. Its not really, however there are different qualities of paints. And a lot of paintshops are switching over to water based paints. Anyways I refer you back to the above pictures of my bike. It is not perfect, however for being my first ever paint job it came out amazing. Everywhere I went people stopped to look at it and asked me where I had the paint done. It felt good to say I did it myself. I did not do it outside and I took my time. Put in a lot of prep work and definitely took my time while painting.
right i'm not bashing because yes you can paint it and by the grace of god it might turn out decent but i've seen cars painted by someone who knows what they are doing turn out like shit because they did it outside. also idk if victory red is but a lot of GM colors are actually pearl. so painting a single piece would stick out even if you knew how to paint unless you blend it. and thats not accounting for the fact that the bumper is plastic vs the metal of the car so that makes it even harder
sorry if i sound negative but you need to know what you're getting into before you get into it.
(Post 6762871)
Originally Posted by brian.olsson
(Post 6762428)
huh, I"m confused,
but painting is not hard at all, its all in the prep work, and all paint can last, just depends on how you take care of it after you paint it. And that's where your wrong. Painting isn't hard but painting good is hard. It takes a lot of practice especially with metallic. Prep work is 100% key but even with good prep if you put the paint on wrong or too much room soon, or mix it slightly wrong you are prone to failure. If you don't clean the surface it will fail, using the wrong materials for the atmospheric tempature your spraying in will cause failure. Using garbage materials with fail even with good prep. That's where I have found people are wrong. I see the prep statement all the time and all it does is confuse people. Its a combination of both good prep and good materials....also its a combination of patience and practice. As far as the guys that want to do ghetto whole DIY thing. It depends....if your meticulous and care about your car and never painted before just pay a good shop to do it and save yourself the headache. If you don't care how your first few projects look then go for it. |
