How much power is too much on a fuse slot?
I hope this isn't a dumb question but I'm sort of electrical stupid so here's my question. I've got 2 LED strips (15 inch) and 4 separate LEDs hooked up to my sunroof fuse in the fuse box. I used an add a circuit and I have my interceptor on the other part. I don't have a sunroof by the way. I'm just wondering if I could hook up another two LED strips to that fuse or if I need to find another fuse? If I need to find another fuse which fuse do you suggest using, I would prefer one that comes on with the car and goes off with it too.
Thanks a bunch in advance. |
all depends on resistance of each item... they would all be connected in parrallel is my guess and being fed 12 volts each... all you need to do is figure out how many amps you have flowing threw the circuit and if its around 14 (which i doubt) then you'll need another fuse
you can have 937819192 leds on a fuse. dont worry my whole interior runs on 1 fuse :)
(Post 1021701)
(Post 1021701)
LED's are pretty safe. The most correct answer is you need to know what the load of the total circuit is and then wire it accordingly, but LED's have a small load.
What you need to be careful of is how you wire it to the fusebox. Very easy to screw that part up. |
Originally Posted by Halfcent
(Post 1022095)
What you need to be careful of is how you wire it to the fusebox. Very easy to screw that part up. How so? Do you mean using the wrong side of the fuse? |
Yes. If you connect AFTER the stock fuse, you are using the stock fuse to protect your circuit. If you connect BEFORE the stock fuse, then you need to make sure you use a separate in-line fuse. Additionally, you have to be sure you pick the right bus to plug into (hot, acc., switched).
(Post 1021701)
Let's see you put 937819192 of those on one fuse without it blowing!! :lol: |
(Post 1022894)
I'm using my sunroof slot to do it and I have the add a circuit thing so that seemed pretty idiot proof. I'm 99% sure it's right. lol |
