How to wire quad retro fit?
Old Nov 1, 2010 | 08:14 PM
nickadolph's Avatar
I want to do a quad retrofit setup, but I don't know how I would go about wiring it in so that I can use two ballasts on each side, any help?
Old Nov 1, 2010 | 08:55 PM
Cobalt08LS's Avatar
hmm. noo cluee
Old Nov 1, 2010 | 09:16 PM
RedStil's Avatar
Originally Posted by Cobalt08LS
hmm. noo cluee
The best usefull post in history!
Old Nov 2, 2010 | 02:44 PM
nickadolph's Avatar
Just an update for anyone else who may be interested, I asked matt at theretrofitsource.com and he said the following.
"Easy! run 2 relay wire harnesses.
Each harness needs only 1 input, but has 2 outputs - so you can use two of them (plugging one into each side of your original headlight outputs) and then you'll instantly have 4x outputs for ballasts, and 4x outputs for bi-xenon solenoids (if you run a bi-xenon harness of course)
The ONLY thing to watch out for is the side opposite your car battery will probably need the wires going to the + terminal on the battery extended. Otherwise you're good to go."
Old Nov 2, 2010 | 02:46 PM
TommyP's Avatar
AWD > FWD
Oh that was you that made that post. I saw that. What car are you doing it on?
Edit, replied on hidplanet.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 07:39 AM
jmelton327
Sep 26, 2015 10:04 PM
