Hydro Dipped Calipers ?
Old Dec 17, 2012 | 12:58 PM
yellowsupercharged06's Avatar
so im curious to see if anyone has hydro dipped their brembo calipers ? Ive been told its do-able, so i may try it out any opinions ??
Old Dec 17, 2012 | 12:59 PM
hmm, hydrodip + high temp clear... sounds doable. u planning to do it in cf or what?
Old Dec 17, 2012 | 01:01 PM
Texas SS's Avatar
No clue
Old Dec 17, 2012 | 01:06 PM
padlock's Avatar
being that I have hydrodipped a few things myself. I'd say it would definately be possible. depending how you dip them though you may have a "stretched" appearance in the pattern in places. what pattern you looking to do?
Old Dec 17, 2012 | 01:34 PM
idk what pattern was thinking about mayb a colored carbon fiber, or a pattern that looks like it has water droplets on it in a electric blue.
im not too sure how the process works and i wana make sure that the water wont get inside the caliper and f anything up... its going to be done by JM auto racing here in long island
Old Dec 17, 2012 | 01:58 PM
iToastie's Avatar
This is how it is done... basically
Old Dec 17, 2012 | 02:08 PM
padlock's Avatar
just make sure to block off where the brake line connects into the caliper and you will be fine
Old Dec 17, 2012 | 02:09 PM
so there put my whole caliper in water lol ??? that dont sound good
Old Dec 17, 2012 | 02:21 PM
C_A_D88's Avatar
U can dry them out....
Old Dec 17, 2012 | 02:27 PM
MastaShaKe_88's Avatar
there was a guy on here that did his calipers I think.. but there's guys that do their valve covers all the time with no problem, so i think you'll be straight
Old Dec 17, 2012 | 02:54 PM
ill just have to find something to plug them up real good then so the water dont go inside and mix with the brake fluid.
Old Dec 17, 2012 | 03:13 PM
padlock's Avatar
just find a bolt with the same thread size.. done
Old Dec 17, 2012 | 03:48 PM
Silverbullet33's Avatar
this is cool process, wish i knew how to do it!
Old Dec 17, 2012 | 05:38 PM
spike's Avatar
Wood grain calipers ftw
Old Dec 18, 2012 | 12:03 PM
TWM Performance's Avatar
WOW! So many possibilities with this technology... Wonder what the limits of this coating process are?
Renato
Team TWM Performance
Old Dec 18, 2012 | 12:07 PM
padlock's Avatar
from what I've done, there isnt much for limits..
basically you spray your primer
then flat base coat (high temp if needed)
then dip
then clear (high temp if needed)
some parts are obviously more tricky to dip than others, but the process itself is fairly simple. Very odd shaped objects are normally the hardest as the graphics will stretch more in some areas than others, but past that the limitiations on dipping is really up to the limitations of your imagination.. whatever you can paint, you can dip
Old Dec 18, 2012 | 12:09 PM
Renato
Old Dec 18, 2012 | 03:04 PM
ill post up pics after i get it done for everyone
Old Dec 19, 2012 | 12:25 AM
would be MINTT if done right
Old Dec 19, 2012 | 10:28 AM
padlock's Avatar
^i second that statement actually
Old Dec 19, 2012 | 10:31 AM
not on my car lmao
Old Dec 19, 2012 | 10:42 AM
padlock's Avatar
i believe there is this pattern called "marble splash". its actually a very cool pattern if you were to say have a yellow base coat on it.
I'm all for going outside the typical "cf" though.. right now my bowtie is cf dipped but thats only because I cant find the digital camo film I'm looking for. I eventually want quite a few parts done in red/white/black digi camo
Old Dec 19, 2012 | 10:44 AM
yeaa the splash mite look sick
Old Dec 19, 2012 | 02:03 PM
pics of somethin done in said splash?
Old Dec 19, 2012 | 02:11 PM
padlock's Avatar
heres marble splash with white base. the silver you see is a really nice metallic
heres a pic of something i found dipped in it.. only with pink base coat obviously
blue
red
