I need your HELP ASAP!!
Ok I'm installing HID lights. There almost done only problem is I have a cable with a green tip and I dont remember where I pulled it off of. It's keeping my drivers side headlight from turning on. Please need your help people. Thanks.
Something else is wrong with your light - try swapping the bulbs from side to side, if the passenger side now fails to light, you have a bad bulb. If it still doesn't work on the drivers side, it's the ballast or the wiring.
Good luck!
I still wasn't sure where it went. So it sat like that for a while until I had to take it in for some warranty work and they hooked it back up. I can take the light out again tomorrow and let you know where it goes if that works for you?
Good deal
I got mine wagg'n around below the light somewhere... I do wonder though,, If the green tip IS the sensor and does not need to be plugged into anything why am I getting a temp reading of ---. Maybe I broke mine =\
I was told it just hooks to the body. Headlight bracket would make sense. But I'm too drunk to go out into the cold to take a look. ******* alaska and getting cold all the time.
