interior door handle
Old Jun 2, 2010 | 12:23 PM
plat's Avatar
I need to replace an interior door handle on my 2005 cobalt ss / sc. The chrome paint is peeling, and the plate that it mounts to is broken. Anybody have any suggestions on where to order one? Also, if the website you find offers a replacement boot for the shifter that would be great, mine's worn down quite a bit.
Old Jun 2, 2010 | 04:38 PM
scottie's Avatar
Mines doing the same. Summer project I haven't started yet. Do you know if you have to remove the door panel to get that off?
Old Jun 2, 2010 | 04:58 PM
cubaniche's Avatar
Mines a year old and the chrome wrapping is all bubbled up too. I think my warranty will take care of this though. I figure you can maybe find a handle from a totaled balt at a yard somewhere and rip it out...???
Old Jun 20, 2010 | 03:10 AM
alchemist1130's Avatar
yeah mines doin the same thing as cubaniches
Old Jun 20, 2010 | 03:13 AM
07cobalt2.2's Avatar
try Rockauto.com they might have it.
Old Jun 20, 2010 | 03:59 AM
Nighthawk243's Avatar
Dealership is the best bet.
Yes.
Covered by warranty. I should know: My car has had 3 of them replaced.
Last edited by Nighthawk243; Jun 20, 2010 at 03:59 AM. Reason: Automerged Doublepost
Old Jun 22, 2010 | 12:21 AM
rockauto doesnt have it, but thanks for the suggestion!
Old Jun 22, 2010 | 12:45 AM
scottie's Avatar
Do you have to remove the panel? I took it out without disconnecting it to look at it. (mines doing the same ****) and it looked like I could disconnect it without removing the panel, but I wasn't sure if the connecting rod would fall into the panel if I did disconnect it.
Old Jun 22, 2010 | 02:03 PM
nosepressthebox's Avatar
I just painted mine with plasti-dip, came out really good. Not sure how it is gonna hold up but it is fine so far after about a month. You DO NOT need to remove the door panel. It's very easy to remove them and put them back in, but it takes a little figuring out.
Edit: Scottie you don't have to worry about that. Unhook the little clip that holds that rod onto the handle, and it comes right out. To put it back in just put the rod back in the slot and put the clip back together.
Old Jun 22, 2010 | 04:33 PM
scottie's Avatar
nosepress- good to hear. Now I just have to figure out what I want to paint my interior...
Old Jun 22, 2010 | 11:07 PM
plat's Avatar
http://www.gmpartsgiant.com/online/P...igPicture=True
Welcome
Old Jan 19, 2015 | 02:41 PM
fridaythe13th77's Avatar
inner door handle
I just replaced my innner door handle today. That think takes all of about 30 seconds to replace. Just take the inner tab off with a flat head screwdriver and take the philips head screw out and pry from the front with the flat head screwdriver and it pops right out. the clip unclips from the bottom just push it backwards and it comes right off. then install the new one opposite of the way you took out the old. Its really that simple... I picked up a new one on ebay for less than 20 bucks.
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
