Interior door panel ?'s
-First off how do you take out the little bezle that holds in the power windows and locks buttons? im painting my buddies interior and need these trim pieces out....
_and for my car i need to know if the SS door panel is the only one that comes in all black(minus insert) or was there some kind of model that had manual windows and locks but full black doors?
_will the SS doors fit if i swap inserts and bore a hole for the window crank? on a Base (05)
Remove the two screws underneath. Lift up the rear while pulling towards the rear. The front has a tab that extends forward. Use a thin bladed knife to remove the buttons from the tabs.
i have the sport package, or what is left of it, lol and i had all black interior except for the A pillars and the roof liner. i took out my door inserts and recovered them in red vinyl. replaced my white 140mph guage face with a red 140mph guage face.
Any coupe trim panel would fit your doors if you drill a hole for the crank. The bezel with the window switches would have to be modified to fill the switch holes though. The bezel with manual windows is shorter. Maybe you could mount switches for something else in the switch holes? Or make a carbon fiber cover. Or aftermarket power windows.
Dennis
Dennis
Dennis
Dennis
