Interior footwell LEDS.
Old Jul 18, 2010 | 12:01 AM
lilskarvcx's Avatar
I have no experience with LEDs, but it can't be too difficult to stick some under the dash to light up the footwells. Do I need anything other than a tap from a battery line?
Old Jul 18, 2010 | 12:39 PM
ryaan's Avatar
just tap your cig lighter. its not too bad. i did it myself with no prior experience. the 1st time i did it it came loose and fcked up though. the 2nd time i soldered and heatshrinked all the connections.
Old Jul 18, 2010 | 12:44 PM
Cptn Pants's Avatar
It's pretty easy to do, get some 12v LEDs and you can't really do anything wrong as long as you don't short them out by connected the + to the - lol. A switch will be nice to control them too, which are very easy to wire.
Old Jul 18, 2010 | 12:49 PM
ryaan's Avatar
yeah, pick up a switch at an auto store for ~4$. a couple fuses too - ive blown like 4 while wiring them and making careless mistakes or letting the wires touch. for the strips, this is where i get mine. they're great and only 5$ for 2. you need 2x30cm (12inch) and you can cut them down too, i cut one down to 6inches and put it under the stereo/above the cig lighter & cup holders (above the cig lighter outlet)
http://shop.ebay.com/lucy3624/m.html...1&_from=&_ipg=
Old Jul 18, 2010 | 04:43 PM
lilskarvcx's Avatar
I want to wire it to the door ajar fuse so that it comes on when I open the door, but I also want to be able to have the LEDs on with the overhead light off.
Is there anyway I can do that?
I also want to be able to dim the lights, what type of resistor should I get.
Old Jul 18, 2010 | 10:27 PM
suprafanatic26's Avatar
check out oznium .com they have it all....
just splice into the cig lighter, as well as splicing into the int Light panel on the pass. side fuse.. then put a on/off/on switch so u can choose either door ajar or always on from the cig...and on the cig end put the dimmer..its pretty simple..
leds
on/off/on switch
and dimmer
lemme know if you need anything else.. make sure you also put a fuse from the switch to the lights just in case..like 2 amps should do..maybe three depending how many you are going to put..
Old Jul 18, 2010 | 10:41 PM
Brizzal's Avatar
I connected mine to the dash light dimmer switch, they only come on with the dash lights at night and a controllable dimmer
Old Jul 18, 2010 | 10:46 PM
Axelthered05's Avatar
Same here
Old Jul 18, 2010 | 11:37 PM
lilskarvcx's Avatar
I can't believe I hadn't thought of that (not sarcasm). Thanks. I popped the panels out to see what I'm dealing with. Which wire of the two is positive and which is negative?
Old Jul 20, 2010 | 04:22 AM
lilskarvcx's Avatar
or does it matter as long as I match the wires making sure they're the same wire to each LED strip.
Old Jul 20, 2010 | 03:21 PM
Cptn Pants's Avatar
I did something like this for my one set of lights (hidden under the door itself) come on automatically when I open the doors. How I did it, was I wired the grounding wire to the button on the door jam there, this way when the button is release (IE the door opens) it completes the circuit and turns on the LEDs.
I used to have my LEDs wired up to the dash light dimmer switch but I have too many lights and I kept blowing fuses... I could have used a relay but I didn't feel like wiring that up so now I just have a switch. I might get a relay soon and wire it up that way because it was cool to have everything come on automatically when it got dark... but I'm taking a break from projects for now.
Old Jul 20, 2010 | 03:46 PM
b00sted06ss's Avatar
^ thats a good idea but wiring can get pretty confusing lol
Old Jul 20, 2010 | 11:57 PM
lilskarvcx's Avatar
once I get my led strips, can i just run a wire directly from the dashboard dimmer to the passenger led strip and tap the driver side led strip off of that wire?
Do I need any resistors?
Old Jul 21, 2010 | 12:49 AM
Cptn Pants's Avatar
If you get 12v LED strips then you're set. You won't need anything extra.
Old Jul 21, 2010 | 01:11 AM
lilskarvcx's Avatar
I made a mistake in my wiring. I tapped off the dashboard lights dimmer which until now i thought were 12v. Turns out they're 3v. I ordered 12v leds *bangs head on table*
Old Jul 21, 2010 | 01:22 AM
Cptn Pants's Avatar
Well... you would pick one of the other. A switch is easy to wire:
Switch
__/___
=LEDS
If that makes sense.
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
Sep 27, 2015 08:53 PM
