interior LED's
interior LED's
Well I just put some wedge LED's in my mirror in the interior (cool white) and they look awesome.
Except they don't turn off all the way. When the door is shut they are very very dim (they don't put out any visible light rays unless you look under the mirror at them you can see a dim glow).
Any ideas what's going on? Was thinking of rotating them 180* to see if that helps bc I know LED's matter which way they are wired.
Most electrical devices are never fully "off". filament light bulbs need to take a certain current to operate, but they emit no light when they are turned off. However, current still passes thru at this point, especially with GMs wire everything on one circuit policity. LEDs require very low current and do not need a certain voltage to begin to emit light.
So in short the low current passing thru is enough to make it glow.
I have not had the time to mess with this for a fix, but I relay could solve it as well as a better led. I know some of them have in line resistors.
Hopefully that helps
This has been an issue with in home lighting, and has been my reason for delay in doing leds in my car.
You will be fine...you could add resistors to fix it but like i said its fine.
The Cause...
There is a always running current of 2.4volts, this is to enable the incandescent bulbs to light up as fast as possible once triggered, not enough to dim the incandescent filament but enough to bring the led to a faint glow...
The Cause...
I agree that adding resistors would be too crazy of a project in that spot, but I believe that some companies run resitors inside the casing. Where did you get yours from?
You are not switching anything to add extra power, so it would ben no different than before. Now you are just aware of it.
I got the 6x LED cluster as well. The LED's aren't a problem for me as long as they aren't drawing anymore power from my battery like you said they weren't. That's all I was worried about. I didn't want to be slowly draining my battery just because I wanted to have LED's. Anyways those are the bulbs I ordered
http://www.superbrightleds.com/cgi-b...ini-wedge.html
