Interior Lighting Question
Old Jan 17, 2011 | 09:39 PM
GRok25's Avatar
Wink Interior Lighting Question
I want to change the bulbs on my rear view and the one in the trunk to blue ones.(2Door)
Any links for the correct bulbs?
Old Jan 17, 2011 | 09:40 PM
SS_NH's Avatar
go to ebay or vleds and look for blue 194 lol.
Old Jan 17, 2011 | 09:49 PM
GRok25's Avatar
i searched both of them and they both show like 200 results. i need a link for one that will definatly fit.
Old Jan 17, 2011 | 09:51 PM
GRok25's Avatar
Will these work???
2 BLUE SMT X5 HIGH POWER LED LIGHT BULBS 194 168 158
Old Jan 17, 2011 | 09:54 PM
TommyP's Avatar
AWD > FWD
Originally Posted by GRok25
Those should work just fine. Email them first and ask if you can return them if they don't fit. They should though, most of the leds everyone else uses are about the same size.
Old Jan 17, 2011 | 09:57 PM
GRok25's Avatar
is there any wiring or do i just plug em in.
and what about my trunk light
Old Jan 17, 2011 | 09:58 PM
TommyP's Avatar
AWD > FWD
You just plug em in. The trunk light is the same bulb. You can put them in backward and they wont work though, so have the light on so that you know if you have it in the correct way before pushing it all the way in. You won't hurt them by putting them in backward if I made it sound that way.
Old Jan 17, 2011 | 10:02 PM
GRok25's Avatar
no i understand. thanks man.
do i use a screwdriver to remove the plastic covers over the lights up front?
Old Jan 17, 2011 | 10:08 PM
TommyP's Avatar
AWD > FWD
ya I used a flathead to pry them off. The real pain is removing the bulbs, they're difficult to grab onto.
Old Jan 17, 2011 | 10:12 PM
GRok25's Avatar
thanks, can you give me another link that you recomend?
1 last thing, will replacing the lights drain more power. (Im overthinking this lol)
Old Jan 18, 2011 | 08:25 AM
Urban Rogue's Avatar
when i put LED ones in mine getting the stock ones out was a BIATCH.
what I ended up using was that thin rubber type material ppl use in kitchen drawers to stop things from sliding around.
was thin enuf and since it was a grabby rubber material i was able to get a grip on the bulb and pull.
Old Jan 18, 2011 | 08:30 AM
cmatthewb101's Avatar
Sub'd
Old Jan 18, 2011 | 08:50 AM
NCC-2000's Avatar
Replacing the bulbs with LEDs will actually use less power than stock, so no worries there.
Old Jan 18, 2011 | 09:06 AM
TommyP's Avatar
AWD > FWD
I've got these
Super Bright LEDs - Miniature Wedge Base Bulbs
Their site is a pain to link to. It's the one in the top section, the WLED-X5
Old Jan 18, 2011 | 06:59 PM
GRok25's Avatar
This is it right? http://www.superbrightleds.com/cgi-b...%2FWLED-x5.htm
Are they bright and will the fit in the trunk too???
Old Jan 18, 2011 | 08:26 PM
SS_NH's Avatar
if you want blue, it may look kinda goofy in your trunk because of the case over the bulb.
I know one guys shined green.
Old Jan 18, 2011 | 08:35 PM
GRok25's Avatar
I think You can remove the cover in the trunk. idk i will have to play with it for a little bit.
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Sep 27, 2015 08:53 PM
