Interior neons
Interior neons
Hey guys it's my first time posting so go easy on me. I have been looking at replacing the stock radio unit (06 ss/sc) with a single din deck while at the same time removing the panel where the heated seat option would go (my car didn't come with it). I would then like to mount a green neon tube light sunk into the dash unit and cover the opening with a piece of Plexiglas that has been black out tinted (possibly frosted?) except for the cut out of pilots wings. While I'm at it i would want to mount two more lights tucked behind the dash in the foot area. I would want to run all 3 lights off the same switch ( i have experience in wiring just never in a car), any suggestions about how to mount the lights what to wire them to (ie. new lead off the battery or tap existing wires?) Would this even look good? Any suggestions, advice or help you guys can offer would be much appreciated.
well, there should be a display that tells you if the pass. airbag is active, its right between the spots where the heated seat switches would be. im sure you could just get rid of it tho.
