Interior Neons?
Old Aug 5, 2007 | 02:11 PM
Cptn Pants's Avatar
Interior Neons?
I got a cheep set of neon tubes from best buy, i think they are about 8 inches long and light up a nice blue and i really like them. The only problem is they plug into the cigarette lighter and now i have 2 wires run along the floor of my car and it looks kind of... cheep. Well long story short I'm thinking of having some neon tubes professionally installed and wired up to the battery, does anyone have any suggestions as to where i can have them mounted for maximum brightness and still have them hidden from direct view? I would like for them to light up the front and back seats so please that that into consideration.
Also, does anyone have any idea where i could go in NJ (preferably around Edision/Woodbridge) to have such a thing done and about how much it would cost me? I've never really had a car nice enough to bother modifying it so I'm a bit of a newb when it comes to it.
Many thanks.
Old Aug 5, 2007 | 02:41 PM
Xavipheus's Avatar
under the steering shaft, under the glove box, under the seats...just run the positive to somthing 12v hot
Old Aug 7, 2007 | 06:15 PM
Cptn Pants's Avatar
Well those do sound like good locations, any idea how much such a setup would cost to have installed?
Old Aug 7, 2007 | 07:12 PM
RedEcotecSS's Avatar
it's really easy, do it your self.. just zip tie them all, it'll hold. as for the power; use an 'add a circuit' to your fuse panel in your passenger side of your car. put the red wire to that, then put the black one under an unpainted bolt or something like that..
Old Aug 7, 2007 | 07:19 PM
Jusday's Avatar
i did this myself with LEDs underneath the dash. i then hard wired them into the 12v lighter by the e-brake. i added a switch that also has a blue LED and it looks sick. i would not pay to have to done personally. i was kinda a noob to wiring and it was very simple, just time consuming, and it looks like a pro install. if you want any help feel free to ask
Old Aug 7, 2007 | 08:24 PM
Slow4dr05's Avatar
I agree with you jusday... its an easy job for someone without lots of experience. I actually put a bigger fuse into the "less important" spot in my fuse box (overhead dome light) and ran the red power wire from that slot. you can hide the backseat wires right through the center console (don't let live ground wires touch the metal next to the ebrake... SPARKS FLY :-)
Old Aug 7, 2007 | 08:29 PM
06redlineb's Avatar
its not good to put bigger fuses in.the wire will burn.the wire is rated for that fuse.
Old Aug 7, 2007 | 08:38 PM
originaladrian's Avatar
or you could just tap into one of the many unused fuses in your cobalt. I did that and they turn on and off with my car.
Old Aug 7, 2007 | 09:12 PM
Jusday's Avatar
i was also later looking at the add a fuse option... it would be simple to do that, there are plenty of open channels in the fuse box by the passenger seat
Old Aug 13, 2007 | 07:37 AM
Cptn Pants's Avatar
Well i had it done over the weekend, it does indeed look amazing. I have them under the dash, under the back of the seats and one 3 inch on under the arm rest, I also had them mount a toggle switch in that cubby hole where the trunk release is. I am quite happy... so what are the chances that i voided my electrical or total coverage warrenty?
Old Aug 13, 2007 | 11:08 AM
black_bullet_gt's Avatar
the chances are none. You didnt void anything. Have fun with the lights.
Old Aug 13, 2007 | 12:37 PM
Bumblebalt's Avatar
wel u said you had it done, didn't say you did it. i am just curious how much it cost you?!
Old Aug 13, 2007 | 05:32 PM
Cptn Pants's Avatar
I had the whole shabang done for $120 bucks...
Old Aug 13, 2007 | 05:35 PM
halfj99's Avatar
wow i could have alot of glow for $120
www.oznium.com
Old Aug 13, 2007 | 05:42 PM
Cobalt_SSTuner's Avatar
^^^ exactly
I got 3 sets of 12" inch tubes for 25 bux plus shipping. I have pictures of mine at home i can post up some pics tonite.
Last edited by Cobalt_SSTuner; Aug 13, 2007 at 05:42 PM. Reason: Automerged Doublepost
Old Aug 14, 2007 | 02:32 PM
Cptn Pants's Avatar
Well i didn't install them myself because i have no talent or skill, and that includes buying the tubes, the wires fuse and switchs and haveing them mounted and the switch mounted in the truck release thingy. I think it was a good deal, and i'm very happy with it.
Old Aug 14, 2007 | 02:46 PM
2fastSS's Avatar
i got mine off ebay...orange tubes and all i did was buy a switch and put the switch right next to my e-brake...a flick of the switch their on and off....I had them put into my 2nd cigarette lighter thats how they get their power...easy enough then its a clean install from there as all the wires are hidden
Old Aug 14, 2007 | 05:37 PM
Jusday's Avatar
exactly what i did. there is a blue led in my switch too... that thing is bright as all hell...lights up my back seats
Old Aug 15, 2007 | 10:34 PM
Whitnith's Avatar
I bought some tubes and a switch off oznium.com, picked up some wire and zip ties from wal-mart and did it myself. The only wires that show are where I have them running into a plug that goes into the cig lighter. I wasn't comfortable hard wiring it, so I did it that route. The switch is in the little area with the trunk pop.
Here are some pics of mine.
Old Aug 15, 2007 | 10:37 PM
vB00STw's Avatar
https://www.cobaltss.net/forums/appearance-48/interior-lights-71009/
^^^ My setup. I tapped into my cigarette lighter and put in a switch
Old Aug 15, 2007 | 11:11 PM
outtamymind's Avatar
here's what i've done so far.
https://www.cobaltss.net/forums/show...85#post1336885
Old Aug 16, 2007 | 12:34 AM
Goode6's Avatar
How do the orange ones look??? I've heard alot of them have more of a pinkish glow than orange.
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
Sep 27, 2015 08:53 PM
