interior neons help
Old Mar 9, 2008 | 02:05 PM
dman090's Avatar
interior neons help
i bought this kit from Pilot and i was wondering if n e one could help me install it cause i dont reallt like the way it looks when i have it plugged into the cig lighter
Old Mar 9, 2008 | 02:07 PM
tombomb's Avatar
well first off, cut that cig adapter off then pull off your dash and hook it up to the back of your cig lighter,.....really easy man, WHITE=12V BLACK=Ground
on the neons wire, one will have a stripe and one wont, if one has a white stripe that means its 12V but if one has a black stripe (highly unlikely) that means it is ground
Edit: you will probably want to run a switch to. that is really easy also, just run the 12v wire to one side of the switch and run the 12V(neon) wire to the other side of the switch, (assuming the switch has 2 terminals)
Old Mar 9, 2008 | 02:11 PM
dman090's Avatar
ok what cig lighter should i plug into and how do i take the dash off??
Old Mar 9, 2008 | 02:13 PM
hinow41's Avatar
Buy LEDS not neon Leds look better
Old Mar 9, 2008 | 02:15 PM
JPizzle's Avatar
I think neons look better in the footwells, b/c it has 180 degrees of light...
& if you want to make them strobe & stuff like that, than neons suck...
dman090's Avatar
well when i bought this tube they didnt have n e leds
Old Mar 9, 2008 | 02:16 PM
mkulrey13's Avatar
well first of all do NOT run a 12v to a switch....run the GND to the switch and directly connect the 12v to the power source.
Old Mar 9, 2008 | 02:22 PM
tombomb's Avatar
start at the dash around the ebrake lever , it all just unsnaps, simply pull and your dash will come apart, use the cig lighter near your ebrake as you will most likeely use the switch around that area
some switches require 12V ie. lit switches, but thats good to know, i didnt think it mattered
Old Mar 9, 2008 | 02:25 PM
leadfoot's Avatar
pilot is so cheap.
Old Mar 9, 2008 | 02:27 PM
dman090's Avatar
Originally Posted by leadfoot
pilot is so cheap.
lol no **** man i just went out there and plugged it in and it dont work n e more..i am gonna take it back...what neons/ leds does everyone perfer
halfj99's Avatar
but decent... ive had streetglow, and plasma glow and there really not much better
Old Mar 9, 2008 | 02:30 PM
tombomb's Avatar
i bought my first set of neons from walmart (now running streetglow) and they didnt work in the cig lighter but once i actually WIRED them to the cig lighter they worked fine and still work fine, i just like streetglows output and colour better
Old Jun 9, 2008 | 07:33 PM
cobaltss86's Avatar
i got pilot in my car and redline in the grill but the grill has built in white strobes what i did was go to the passenger side take off the panel on the left with the little vent in it by ur feet n u got the fuse box there look at the labels n find the amp then cut the cig plug off n divide the wires about 8 inchs or so n then there both see thro but one has a white line in it thats the pos hook it up to a switch and then get a piece of wire n hook it up to the fuse just pull the fuse out of the amp and grab the wire for wrap it around the fuse and plug it back in and hook it up to the switch ( a 2 terminal switch) and then find a peice of metal by the ebrake its already got a ground on it un screw it and put a wire around it and run it to ur neon light and twist the wire together n turn to switch on it should light up if so then tape the negs together and hide the neon and install the switch ur done my pics are here
Old Jun 9, 2008 | 07:34 PM
Acey's Avatar
Why does it matter.
Old Jun 10, 2008 | 12:24 AM
jacobmprater's Avatar
i have OPTX in mine. check out my write up in the how to section. its how to- interior lights
Old Jun 10, 2008 | 09:23 PM
Cptn Pants's Avatar
Jesus cobaltss86, I dont know if it's the brand or the diamond place flooring but yours look a lot brighter then mine!
Sorry about the crap image, it was more centered around the cup holders not the neons.
Old Jun 11, 2008 | 12:35 AM
cobaltss86's Avatar
yeah mine are the **** lol
Old Jun 11, 2008 | 04:49 AM
JayB1127's Avatar
Please explain, Ive never heard this before.
Jay B
Old Jun 11, 2008 | 11:16 AM
joeyblaze's Avatar
when you guys are connecting the wires, are you soldering or just twisting them up and using some tape?
Old Jun 11, 2008 | 01:03 PM
Acey's Avatar
Soldering is the safer and more secure bet, but you can get away with just twisting and making sure all metal is covered with tape. I have tons of wiring in my car, and it would have been a pain to solder it all so some is taped.
Old Jun 11, 2008 | 08:44 PM
cobaltss86's Avatar
well it will work the same run a wire to a ground then connect to the switch then take the ground from the light and run to the switch then connect ur postives and when u flip the switch the grounds connect turning the light on but the postive is always on
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
Sep 27, 2015 08:53 PM
