John powell harness bar finally installed
Bought it off will aka ls1fbody took it to get powdercoated flat black will came over today and helped me install it looks great! now to get a harness im thinking red scrothe 4 point should be just fine plus there street legal...
Schroth Rallye Cross Harness Belts at Sube Sports - The Racing Equipment Source
john powell racing you can email him or pm him on here hes a supporting vendor now and yee thanks mikey i had the same ones in my cavalier with a custom builty harness bar but the blue ones
i installed my harness bar a week o so ago. and i noticed the 3 bolts on one side pulled in a lot more than the other side. like one side the the bolts are showing threads out of the nuts and the other side the the bolts didnt tighten that far in.
But bar is fully bolted in and installd correctly
did u have that issue?
looks great btw.
looks great btw.
If you torqued one side down before the other, that will happen. Did you follow the directions and leave all the bolts loose while installing it and then tighten them down after everything was in? That could be your issue...
...I would try loosening all the bolts and then re-tightening them while alternating sides, not torquing one down all the way and then going to the next.
u may have to lengthen or shorten the down rod spherical joint, cars are not the same in that area, thats why a rod end is used. and a spacer between the rod end is supplied. some cars need a washer between the top seat belt anchor bolt and the harness bar plate, so the seat belt does not rub against the harness bar plate and not retract easily.
ya the bottom rod end has the spacer it in and everything, the bar fit perfectly. just noticed that on the 1 side the 3 bolts tightened up a lot more than the other 3 bolts on the other side.
i followed the directions perfectly also
here is a quick pic of the lime green bar u made for kxrider. he parted his car out so I grabbed the bar off him. Even tho I am a blue theme, this color is soo bad ass!
Ya i did notice that my seat belt doesnt retract that easily but i saw I can just add a washer to push the plastic away from the harness bar plate.
ya he decided to get a honda s2k in the time period when u were shipping it out to him.
and yes my passenger side 3 bolts pulled in more than the drivers but my doors close fine and everything lines up perfectly still
dont let them, or unbolt the main bar.
sorry i am not mike lol but figured I would chime in my ideas. I am saying no to back seat drivers because those 6 bolts take too long to take out lol
and lol yea so no fat people..theres now a weight requirement haha..but yea of course..
