Keeping foglights on when using high beams
Old Mar 30, 2009 | 04:27 PM
metroplex's Avatar
I am still waiting on my 09 SS/TC order, but I was wondering if anyone wrote a how-to on keeping the fog lights ON when you use the high beams (either flash to pass or regular high beams)? I am considering HIDs for the foglights and keeping the 9007s as halogen (Sylvania XtraVision FTW). Flashing the HIDs on and off is bad for the salts in the capsule.
Old Mar 30, 2009 | 04:29 PM
umrdyldo's Avatar
I haven't seen a fix for this, but I wish there was one.
Old Mar 30, 2009 | 04:30 PM
wardzach2007's Avatar
Mine stay on? I think...
Old Mar 30, 2009 | 04:31 PM
rallyracer's Avatar
Originally Posted by liljone
wtf o.o
He doesn't want to F**k up his HID's...
I have no idea if anyone has been able to do this but great question.
mkulrey13's Avatar
I jsut run my fogs off my DRL fuse...they stay on all the time.
Old Mar 30, 2009 | 04:33 PM
majourpain's Avatar
nope you will have to do some wiring and youll need a relay to have this done as far as i know no one has done it. its actually illegal to have the fogs still on when you have high beams on too.
Old Mar 30, 2009 | 04:34 PM
zay52790's Avatar
im sure you could wire it using a diode, so that turning on the highbeams would also power the foglights,
you could also use a relay to do the same thing.
Old Mar 30, 2009 | 04:35 PM
majourpain's Avatar
the only way other the the DRL fuse tap with a relay is to splice into your high beam with a relay i belive.
Old Mar 30, 2009 | 04:44 PM
INDColtsFan18's Avatar
Yes, that should work.
mkulrey13's Avatar
read above..
I do not use a relay, good ol add-a-fuse. 2 years going strong.
Old Mar 30, 2009 | 04:49 PM
liljone's Avatar
no no when I click on the forum it was blank and it was like wtf.must been a bug on my side.
Gestapo007's Avatar
when you just press back on the turn signal switch a little bit to flash it doesnt cut your fogs off. When you click it all the way back to put your high beams on it does cut the fogs off. Flashing you should be fine. I dont find myself flashing cars all that much for me to worry.
Just carry a flashlight and youll be fine
no_ss
Oct 18, 2015 11:58 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Slick_Nick
Sep 28, 2015 09:15 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
