LED Map Lights
LED Map Lights
hey guys, i just bought a set of Eurolights LED 194 for my map lights they work amazing, but i noticed last night that the lights were on really dim once i locked the doors, the stock blubs complete shut off but the leds stay on really dim. im confused? i checked them turn them around a still the same thing?
Any Ideas what it can be?
thanks
mike
thanks
mike
The LED's are obviously pulling some sort of current. It doesn't take nearly as much power to run the LED's as it does the stock 194 incandescent bulb, so there's prolly always been some power running to them, just never enough to show on the stockers. Unfortunately, the only thing to do to fix this would be take the LED's out and put the stocks back in. I don't think you run any risk of killing your battery as those things use hardly any power at all so you'd be ok to leave them in too.
same here its always been doing it, even when you had the incandescent bulb there. So if it was going to kill your battery it would have by now. I like it, i think it looks nice in pitch darkness. a neat accent. I think maybe it has to do with the keep alive now that I see it's not just me.
I had the exact same issue happen to me. I put the led's in and they still glow but it's killer shines on my disco ball during night rides lol . Our batteries have that load sensing on them if anything is left on then it will shut if off anyways true or not shouldn't harm it any. I actually thought they went out after a certain time frame. Still working on that theory. I always forget to check in the morning to see if they are still on.
Another reason why this site is Awsome
I loved that when i was in my friends HHR I was thinking of trying to do it my self in my cobalt one day. Get that exact part its mounted in, if I remember correctly its in a little plastic insert.
Since it takes more power to light the incandescent bulb it doesn't light, but LED use far less power so they light up a little. either way that current is flowing.
^^oh yeah... oops lol
If you're looking for LEDs I'd look at superbrightleds.com. I got mine off ebay before I knew about that site, or even css.net for that matter.
The ones I used are similar to these: http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
I get all my LED bulbs from V-LEDs. They have a huge selection and their bulbs are excellent quality and function just like they're described.
To get the LED to turn off then the motor is off, you need to have a 1 ohm resistor on pos side of the contact on the LED bulb, this will stop the current running into the LED.
And yes the LED isn't really going to effect the battery, but its still putting a load on it. less than 1 volt.
z28addiction
Sep 28, 2015 12:03 AM
