led outer tail project from friend
not possible... cost is too high and theres a minimum order to make the boards plus profit is an issue as well. Now what i was thinking was for a sorta universal board with a pos/neg for both an outer halo and for the inner circle. Then people can decide if they want to wire it as either a whole piece (all leds on or off just like stock) or if they want to customzie it. Im nto sure 100% on the wireing but the stock tail light has a dual filimate bulb so there might be a way to seperate running lights and turn signal/brake light... also you can splice the 3rd brake light for another option as well. If you could seperate those signals then finding 20+ people to sign up for the "universal" option ive stated shouldnt be a problem... The only "concern" i have with any setup that comes out is personally id like to see a type of seperator for the inner/outer led's. From the video of it posted in the housing i dont see as much of a difference between the inner halo and the outer halo as id like to... with the outer only it pretty much lights up the entire housing and the same is true with the inners only. If it was a more defined look id love it much more
z28addiction
Sep 28, 2015 12:03 AM
