looking for the smaller wing
im looking fr the smaller wing not the stock one it has different ends on it only seen it on a few cobalts but not from a vendor i wanted to et a better look and see how much those run for
This spoiler?
http://www.crateenginedepot.com/stor...P1766C203.aspx
Ive seen it in person on a coupe and it doesn't look that bad. Id say get it for sure if you're looking for a low rise wing.
Pics can be seen here:
http://www.cardomain.com/ride/2923020
I have the one that is pictured on the white car. It's a little thicker than the one that CED sells and I'm pretty sure it does not line up with stock holes. My car was wingless but the posts did not line up with the holes in the underside of the trunk.
for the love of God, the one pictured on the white car does not line up. In fact I had to add longer studs to mine just to get it to go all the way through the trunk. I had a pic of the underside at one point but I dont have it online so I gotta dig it up.
Did you buy an aftermarket one or GM one? The GM one should bolt right up.
I bought the one pictured on the white car.The site I bought from had the exact same photo minus the background, so more than likely the same spoiler right? That one will not fit. The GM wing has thinner uprights and pointier ends. Someone here has a red car with one installed. I think it's called "unique" or something like that. Might fit might not, I dunno. I'm just saying the one on the white car is not the same wing as the one from GM
patooyee
Oct 1, 2015 01:07 PM
Cptnslo
Sep 24, 2015 09:32 AM
