Moisture in headlight
Originally Posted by Re4peR26
Well last night after washing/ waxing my car i descoverd my passenger headlight has mosiure in it is there i way i could possibly get it out??
Originally Posted by LittleStealthSS
I would say that if it's still under warranty.... then make them take care of it.
Karla.... when you going to take YOURS to the dealer for that??
LSX RWD S/C conversion
headlights
i painted mine.
had some moisture find its way in.
heres what you do.
take the headlights out of the car.
remove wiring and light bulbs.
bake in oven at 200 degrees for ten min at a time allowing for cool off
the water will evaporate out due to the heat
then buy some permatex black and seal it up.
or if you havent done anything then the headlight should be taken care of under warranty.
heres what you do.
Originally Posted by SSpartan
i painted mine.
heres what you do.
heres what you do.
I didn't get any moisture in mine after painting them,,, just make sure you seal them up well and be careful when replacing bulbs in the future. You should never get moisture in there again unless the headlight isn't sealed properly in the first place.
But IMHO do not drill holes in your headlights, replacements are not cheap.
brickloaf
Sep 21, 2015 02:17 PM
