molding prob
Old Oct 13, 2009 | 12:51 PM
red2006 ls's Avatar
molding prob
i just took off the side molding but i still tape is still on there i scraped it and used goo gone but its sttil there any other way to get rid of it not using gas
Old Oct 13, 2009 | 12:54 PM
daythecountrydied21's Avatar
plastic ice scraper. goo gone gel. take goo gone gel and put it almost right up against car and take shop towel and spread it over the leftover residue. let it sit a few minutes and then go at it with the plastic ice scraper. don't put a corner of the scraper in the paint or else you'll chip it out.
Old Oct 13, 2009 | 12:57 PM
D4u2s0t's Avatar
goo gone, and some heat. A hairdryer will work to make it easier to get it off.
Old Oct 13, 2009 | 12:58 PM
08two.two's Avatar
I used that Bug and Tar Remover spray on mine, it worked fine. Sprayed it on let it sit for a min and rubbed it away. Probably same stuff you used though. When I took my F-150's side moldings off I used a blue gel wall paper adhesive remover called Dif, it softened that 15 year old tape right up and I scraped it off with a plastic paint scraper.
Old Oct 13, 2009 | 02:22 PM
red2006 ls's Avatar
i used goo gone jell and a ice scraper got most the big stuff its just the resdue off the tape i might try heat and scraper will that work
Old Oct 14, 2009 | 09:04 PM
08two.two's Avatar
After I peeled the emblems off the bug and tar remover got rid of all the residue, I sprayed it on and used a soft kitchen scrub pad and it rubbed right off. Didn't mess the paint up at all, have you tried it?
Old Oct 14, 2009 | 09:07 PM
JOHNNY C's Avatar
WD-40 will work also without hurting the paint
Cobalt08LS
Jun 19, 2016 07:29 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
dieGone
Sep 23, 2015 10:20 AM
chris88z24
Sep 8, 2015 01:55 PM
randy1kleeman
Aug 28, 2005 12:55 AM
