Money to spend: CCFL or LED HID
As the title states, I have some money lying around and it's wanting to be spent. I am looking at buying some new lights on ebay, just not sure which ones I want. It would have to be easily installed , I have very little electrical wiring/soldering skills whatsoever. I would just like some input about what ones I should get(pros,cons). Any ebay sellers I should stay away from? Thanks!
the easiest one would be CCFL headlights because it is plug and play while all the other versions require some sort of wiring (as far as i know)
you can also consider getting the tail lights from ebay too
Think these are CCFL Gen III?
I am a big fan of the 3rd gen projectors
http://cgi.ebay.com/ebaymotors/CHEVY....c0.m245.l1318
No it doesn't look that bad with Halogens, of course HID's would look so much better but for now the halogens they give you will be ok.
CCFL is the halos, much much brighter than standard led halos.
CCFL stands for Cold Cathode Fluorescent Lamps
And there a completely new housing.
okay, but its just plug and play, by that i mean i don't need to put anything in them, not bulbs or anything you said "open fixtures for the highs." does that mean i can put highs in them, but i don't need them to get good lighting?
Yea I know, a local Balt owner has them and he can drive with out his lights on and the CCFL's are bright enough to see.....awesome hands down. I will probably be upgrading to these soon.
so the ccfl is better because of no led, i want to set it and forget it, so will upgrading them cost me later on?
JUST SET IT.............*audience* AND FORGET IT
R.I.P Ron Pompeii
Did a quick eBay search, I dunno about the seller but you can search for others. And the CCFL's are white not blue.
http://cgi.ebay.com/ebaymotors/05-07...spagenameZWDVW
What do you expect from a foreign company. At least they give you a one year warranty.
Thanks for the info everybody! Will be placing an order asap
P.S. I have a black 'balt, what would look better in your opinion(s), a black, clear or chrome light housing?
if you like the black out look then black would be the way to go. i would personally pick chrome for black
