My Halo projector LEDs dont work :(
Old Sep 14, 2007 | 11:28 PM
roccobladr's Avatar
i followed 2 of the how tos and both say that u just twist the 3 white wires together and then the 3 black wires together.
well i did this many times to make sure and i still cant get the LEDs to work. i tried recutting the wires and twisting them back together even wrapped tinfoil around it. still nothing
any ideas?
all the other lights work
also, the top lights arent orange...arent they supposed to be?
Last edited by roccobladr; Sep 14, 2007 at 11:28 PM. Reason: Automerged Doublepost
Old Sep 14, 2007 | 11:30 PM
JRANGER's Avatar
any ideas?
YOur LEDs are probably bad. If one doesnt work they all dont.
Old Sep 14, 2007 | 11:31 PM
roccobladr's Avatar
is it uncommon for them to be bad in both headlights?
Old Sep 14, 2007 | 11:33 PM
jlmd's Avatar
try turning them different ways in the sockets...different combinations...the LED's are directional and will only work in one direction...
Old Sep 14, 2007 | 11:41 PM
roccobladr's Avatar
how do i turn them lol. like i didnt touch the actual LEDs at all. all i did was get the 3 white wires and twist them together and get the 3 black wires and twist them together...am i missing something?
Old Sep 14, 2007 | 11:42 PM
Sunburst_SS's Avatar
which wire did you tap the white wires into? and what did you tap the black wires into?
Old Sep 14, 2007 | 11:43 PM
nramlow2006's Avatar
MAYbe you wired them wrong.. ? lol..i have 2 bad halo's right now.. its bull **** if you ask me
jlmd's Avatar
pull the sockets out of the holes and remove the bulbs and put them back in the socket in the other direction...try different combinations and I bet they'll work.
roccobladr's Avatar
i didnt tap them anywhere. the wires were already connected to the LEDs when i opened the box
Old Sep 14, 2007 | 11:44 PM
yes....but the wires need to actually be wired into a power and ground source..
Old Sep 14, 2007 | 11:45 PM
roccobladr's Avatar
oh lol well all i did was follow the basic how to and didnt say anything about that. the LED wires are just going from the LEDs themselves and then twisted together.
Old Sep 14, 2007 | 11:49 PM
the white wires will need to be connected with the brown wire on the headlight harness, and the black wires will need to be connected to the black wire on the headlight harness.
Old Sep 14, 2007 | 11:53 PM
roccobladr's Avatar
oh **** i had no idea lol. how do i go about doing this? i have the browns cut and retwisted and same with the blacks. they have those little white thingys on the end.
i used this how to
https://www.cobaltss.net/forums/show...tall+headlight
Last edited by roccobladr; Sep 14, 2007 at 11:53 PM. Reason: Automerged Doublepost
Old Sep 14, 2007 | 11:55 PM
well, I suppost you could twist the three white wires together, use a butt connector and connect them all to one wire....then use that wire and use a wire tap, and tap into and connect it to the brown wire.......Then do the same thing with the black wires, but connect it to the black wire on the harness instead of the brown.
Old Sep 14, 2007 | 11:57 PM
roccobladr's Avatar
is there any other way without adding any wires cuz as u can tell im not really good with this kinda stuff
Old Sep 14, 2007 | 11:59 PM
nope....to hook them up you need to do a little wiring
roccobladr's Avatar
dammit. well could you give me a little shopping list of things to get at radioshack?
Old Sep 15, 2007 | 12:05 AM
ummm....some butt connectors, and some wire taps, and some electrical tape and you should be good to go....plus + back at ya
oh...also some wire about the same size......maybe 16-18 gauge??
Last edited by Sunburst_SS; Sep 15, 2007 at 12:05 AM. Reason: Automerged Doublepost
Old Sep 15, 2007 | 12:07 AM
roccobladr's Avatar
thanks so much man. hopefully ill have a thread posting pics of my success tomorrow!
Old Sep 15, 2007 | 05:56 AM
HunterKiller89's Avatar
all you need are parts that look like this
http://tnblnx3.tnb.com/emAlbum/album...tors_intro.jpg
cut the brown wire....twist together the two ends of the brown wire with the 3 ends of the white wire, then twist one of those little connector caps on top (the yellow size fits nicely)
then do the same with the 3 black wires, and the 2 ends of the black wire that you are cutting
Old Sep 15, 2007 | 10:58 AM
roccobladr's Avatar
sweet! thanks man! +1 for you too
Old Sep 15, 2007 | 11:14 AM
so did you get them hooked up??? +rep back to you as well
Old Sep 15, 2007 | 12:25 PM
roccobladr's Avatar
i got them working! except the passenger side only the middle LED lights up. all the other lights and the halos seem to be fine though. any reason why? the driver side is all good to go.
also, am i supposed to put an orange bulb on the top part?
Old Sep 15, 2007 | 12:28 PM
steddy2112's Avatar
Indeed
Old Sep 15, 2007 | 12:29 PM
roccobladr's Avatar
**** so is it illegal to drive without it?
