My latest Tail Light Mod
thank you...thats really easy....now ill see if i can make them blink together...like the corvette lights....when you hit the blinker both left lights go at the same time...or vice versa
what size resistor is that?
Last edited by mrsilent13; Jun 13, 2008 at 12:23 PM. Reason: Automerged Doublepost
Yeah without the diodes, if you hit the brakes, your parking lights or other lights would turn on as well. Good way to confuse people on the road lol.
As for the resistor size, I don't really know what it is. I just bought a handful of random resistors at a surplus store and tested out each one until I found one that would produce a level of dimming that was as close as possible to the parking/brake effect.
Also, to make each side blink with the signals, you would just apply the top half of the diagram to both lights, without joining the lights together like I did. I also used the brake wire from the 3rd brake light in the trunk, cause it was closer and it was one less wire I had to run up the trunk lid. You would have to use the brake wires from the left and right outer lights to get the blinkers to work the way you want.
mayb you can let me know what the color bands are on the resistor....and what size diode that is
Last edited by mrsilent13; Jun 13, 2008 at 02:21 PM. Reason: Automerged Doublepost
Any electronics supply store sells diodes, I just had a pack that came with a whole bunch of them and used the ones that were rated for well above 12V. The strips are already designed for a vehicle's 12V electrical system, but I had to use another resistor so that I could keep them at a dimmer level for the parking lights and full brightness for the brakes.
The how-to write up already exists, I just changed how the lights are wired up.
https://www.cobaltss.net/forums/how-guide-43/how-chevy-skyline-tail-lights-87841/
Used the flexible LED strips you can buy from http://www.oznium.com plus a few diodes and resistors
http://www.made-in-china.com/showroo...-Fogstrip.html
Yeah... It's just a resistance difference. There is a heavier resistor on the outisde light 12v turn signal wire... so it takes a second longer for the resistor to load then the light. If that makes since.
As far as our lights, the problem i have heard is that they are controlled by signal through the pcm, there isn't an actuall turn signal wire it's the same power wire as the brake light, so when you hit the turn signal it sends the signal through the pcm to a relay that turns off the brake and on with the turn signal.
So I have heard...
So I have heard...
so if i were to try that synchro thing with a resistor, where would the resistor go in here? as you had said too our tail lights go through a pcm. is this going to affect my install project?
[/QUOTE]
[/QUOTE]
That's called sequential lights, not synchros, and I doubt that would be an easy thing to pull off on a Cobalt, considering how many lights we have to work with compared to a Mustang.
z28addiction
Sep 28, 2015 12:03 AM
