Need fog light help...
Old Oct 8, 2011 | 11:43 AM
Tstonee's Avatar
I bought some H11's and "Fog light bulb harnesses" off EBay..
It was $20, so i figured if it didn't work, oh well it's only $20..
Here's what I have..
And here's a picture of the connector..
Could someone tell me where the other end even plugs into?
Or hell, if it'll even work!?
Any help is appreciated.. Thanks!
Old Oct 8, 2011 | 08:34 PM
scottie's Avatar
lol did you burn out your old harness? the bulb should plug into your existing one.
Old Oct 8, 2011 | 11:55 PM
Cobalt08LS's Avatar
unplug the harness from the bulb in the pic. than unplug the bulb from the harness in your car and replace it with this one. you got an extra harness for nothing pretty much. all you needed was the bulb.
unless your stock harness is messed up
Old Oct 8, 2011 | 11:59 PM
edwardfaria08ss's Avatar
dose your car come with fog lights. cause if it dosent then the power harness wont be there for them. u would have to wire up a switch and a fuse and other crap to have it work. not to mention the fog light bulb housings
Old Oct 9, 2011 | 03:21 AM
Tstonee's Avatar
I currently have no bulbs... and whatever the hell plugs into the back of them....... don't ask why
Old Oct 9, 2011 | 10:21 AM
SSBalt's Avatar
Y?
Old Oct 9, 2011 | 05:09 PM
Cobalt08LS's Avatar
did you buy ur ss n get robbed from the foglights.? how do you not have a bulb or plug harness
Old Oct 9, 2011 | 07:38 PM
Tstonee's Avatar
Let's go with that.. now give me answers.
Old Oct 9, 2011 | 07:49 PM
Tcobalt421's Avatar
do you have an ss or ss/na? if not you might not have the slots or space for them and they wouldn't be wired up for that, if you do have the ss, or 2.4, then their should be a stock harness going into the foglight projector, it looks like you should then be able to just unplug the lights you had in their and plug that one in, if you were looking for hid fogs you would need a ballast along with an hid bulb connector
Old Oct 10, 2011 | 10:47 AM
Tstonee's Avatar
Okay I need the stock harness then......
Where can I get that?
Old Oct 10, 2011 | 05:19 PM
Tcobalt421's Avatar
you should have one if you have an ss/sc do you have foglights>?
Old Oct 10, 2011 | 05:26 PM
so confuzzled.
tstonee, does ur car HAVE foglights or not?
i mean tell us what you have, an ss, a lt, or a ls. i know all ss's have foglights, where it comes down to just putting the new bulbs in. if it doesn't have fogs then you're s.o.l. unless u wanna make housings for them and everything
Old Oct 10, 2011 | 05:39 PM
Tstonee's Avatar
I have the SS/SC.. It COMES WITH fog lights, and the harness...
Long story short, I ripped WHATEVER plugs directly into the back of my fog lights.. That is what i'm looking to get.
Old Oct 10, 2011 | 05:42 PM
sooo take out ur headlights,
see where u 'ripped' whatever out, and replace it! simple, if u broke the plug or w/e then ur in good shape because u got new ones. so i think ur all set right? just go try it if u don't get anywhere post back
Old Oct 10, 2011 | 05:49 PM
Tstonee's Avatar
Well on one side, there's wiring that goes to my horn, and it's good, and then it looks like it splits off and goes to my fog........
Right after it split off away from the horn, it ripped......
Old Oct 10, 2011 | 05:51 PM
idk man id need to see a picture. if it like ripped the wire out of its socket u might have to do some stripping/reconnecting maybe?
Old Oct 18, 2011 | 01:41 AM
murdy81's Avatar
op did you ever figure out the problem?
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
