New Trunk Floor
Old May 27, 2012 | 09:52 AM
biniecki's Avatar
New Trunk Floor
Just finished installing my new trunk floor. I had seen the how to for a solid floor which gave me this idea. I used a sheet 7/16 OSB as it was about the thickest i could go with and still have clearance for my subs. I traced around the old mat and then cut it out with a jigsaw. I also cut out an opening above the spare tire / battery area and cut the remained in half. I sanded the edges and wrapped the pieces with a black vinyl attaching it with staples to the underside.
To do my access panel I screwed on a couple of flat piece of metal to the bottom of the side boards and then grinded off any part that stuck threw with a dremel so it was flat on the top side. I have 6 of them install around the edges to hold the access panel in place. I did this before I covered the wood so that nothing would show
Old May 27, 2012 | 09:56 AM
donald's Avatar
sweet i need to do this but i have no trunk floor liner to match it to lol
Old May 27, 2012 | 12:24 PM
EmperorJJ1's Avatar
nice thats legit other then the box ******* it up a lil
Old May 28, 2012 | 12:13 PM
Cobalt08LS's Avatar
nice! i like this!
Old May 28, 2012 | 12:27 PM
Im liking this!
Old May 28, 2012 | 03:21 PM
mrader88's Avatar
That looks good, i did similar but just carpeted it and added some hinges to open the bottom up, was thinking of redoing it in sued... Hmmm
Old May 28, 2012 | 06:47 PM
biniecki's Avatar
I originally thought about hinging it but I didn't want the hinge to be visible. I couldnt figure out an easy way to do it so I came up with just a dropin piece that worked out better than expected.
Old May 28, 2012 | 07:00 PM
Mr.Tozzi's Avatar
Looks good, I have to get mine redone, I had a jug of motor oil leak in my trunk and the stock stuff is all warped.
Old May 28, 2012 | 08:29 PM
mrader88's Avatar
Yea i found some small black hinges and against the carpet u cant see them at all, even put a little knob like a drawer or cabinet would have and it works perfectly for now if i recover in sued i may just do the drop in like u have, is that opening big enough to get ur spare out of?
Old May 28, 2012 | 09:43 PM
ColeMart's Avatar
***stupid question alert*** What's the point in doing this? Is it to secure your stereo equipment to?
Old May 28, 2012 | 10:03 PM
EmperorJJ1's Avatar
no but you can. the point is because the stock fiberboard thing is thin and flimsy + vinyl looks better
Old May 28, 2012 | 10:14 PM
biniecki's Avatar
I don't use or have a spare doughnut anymore. With the car being lowered and having the body kit installed I can only use a full size spare which I sometimes keep in my back seat. The opening is probably wide enough for a doughnut but it may need to be a little deeper. I only made mine go back about 15" due to the sub box.
The point of this was mainly to make a more sturdy trunk floor. The original pad / carpet had gotten warped from the weight of my subs along with me constantly lifting it up at the front to get access to the battery. By using the OSB its can hold a lot more weight than the flimsy stock stuff. It also allowed to me to make an access panel to the battery which shouldve been stock from the beginning. Lastly I think it looks better than the stock stuff that was there. I had thought about using a carpet like fabric and fiberglassing it all but then i wouldve been afraid to put anything back there for storage lol
Old May 28, 2012 | 10:39 PM
Im thinking of hinging on the back side when I do mine
Old May 28, 2012 | 10:54 PM
rekameohs_nire's Avatar
looks good. Same subs i have too
Old May 28, 2012 | 11:02 PM
heinen02's Avatar
Never even thought of this, i broke my stock one in half so i had easy access to the battery lol. I think i know what my next project is. Great work looks good.
Old May 28, 2012 | 11:09 PM
EmperorJJ1's Avatar
lol wow broke the stock one. hey i guess it works but damn
Old May 28, 2012 | 11:15 PM
heinen02's Avatar
I keep my cables with spare, someone needed a jump and i had a trunk full of stuff lol. did what i had to do. but made life easier down the road every time i needed to get in there again.
Old May 28, 2012 | 11:33 PM
EmperorJJ1's Avatar
true i just wouldnt have ever thought of that.
Old May 28, 2012 | 11:35 PM
heinen02's Avatar
Im in Alamogordo
Old May 28, 2012 | 11:40 PM
heinen02's Avatar
Yeah, i have seen that but to far of a drive for a weekday :/ Sorry for thread jack lol
Old May 29, 2012 | 12:16 AM
ColeMart's Avatar
Thanks guys. And it defiantly does look better.
Old Jun 2, 2012 | 06:35 PM
DannyG's Avatar
How wide did you make the opening?
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
