Official Powell Harness Bar Thread
Who has them? Post Pics
Just got one! Is there an Install how-to?
(Post 7078829)
remove seat belt shoulder straps from holder; move both front seats forward and tilt back forward also.
remove bottom seat belt anchor at the B pillar. T 47 unclip plastic cover carefully remove top seat belt anchor, removing carefully to not leave behind the two spacers; these should be secured with a captive speed nut. unwind captive nut,remove spacers, and place top belt assembly onto the hockey stick shaped down bar. stock bolt/seat belt NOTE IF BELT ANCHORS ARE VERY HARD TO REMOVE USE LIGHT HEAT TO SOFTEN LOCKTITE ON BOLT. Using top bolt as a guide, install top belt/washer/down bar/two spacers/speed nut and install into upper b pillar do not torque down. install lower belt connection. first make sure the rod end is adjusted so the new lower belt slips easily into the anchor and threads without any tension on it from the down bar. adjust rod end as needed. then assemble onto bolt: belt assembly/rod end/spacer and thread into lower mount. repeat other side. assemble bar onto down bars. rotate end for end and on itself to line it up properly. If you have to force it you have not got it lined up correctly. belt guides face up. snug bolts easily each side. torque bolts. done. |
email me I send you one...I have been too busy should have done that when I shipped it. sorry.
(Post 7077606)
I heard there awesome, and that there built really well. Congrats on getting one. I couldn't bring myself to buy it at full price though. so ill be buying a used ottp hardcore. Wish I could get the real thing, but just to much money.
(Post 7078684)
i haz one
(Post 7078674)
you haven't responded :poke:
1 Attachment(s)
https://www.cobaltss.net/forums/appe...talled-256839/
remove seat belt shoulder straps from holder; move both front seats forward and tilt back forward also. remove bottom seat belt anchor at the B pillar. T 47 unclip plastic cover carefully remove top seat belt anchor, removing carefully to not leave behind the two spacers; these should be secured with a captive speed nut. unwind captive nut,remove spacers, and place top belt assembly onto the hockey stick shaped down bar. stock bolt/seat belt NOTE IF BELT ANCHORS ARE VERY HARD TO REMOVE USE LIGHT HEAT TO SOFTEN LOCKTITE ON BOLT. Using top bolt as a guide, install top belt/washer/down bar/two spacers/speed nut and install into upper b pillar do not torque down. install lower belt connection. first make sure the rod end is adjusted so the new lower belt slips easily into the anchor and threads without any tension on it from the down bar. adjust rod end as needed. then assemble onto bolt: belt assembly/rod end/spacer and thread into lower mount. repeat other side. assemble bar onto down bars. rotate end for end and on itself to line it up properly. If you have to force it you have not got it lined up correctly. belt guides face up. snug bolts easily each side. torque bolts. done. |
Royce has this done perfectly. If you are missing the stainless washers to space the belt out, either buy some at the hardware store(9/16 inside hole) or i will mail them. I did not send them out the last shipment, shipper was day dreaming...
(Post 7078674)
4 Attachment(s)
if the bolts are really hard to get out and nothing seems to do the trick..... light heat with a mini butane torch will do the trick to loosen the lock tite.
clicky!!
2 Attachment(s)
2 Attachment(s)
(Post 7078826)
where are you sending the emails?
(Post 7078829)
remove seat belt shoulder straps from holder; move both front seats forward and tilt back forward also. remove bottom seat belt anchor at the B pillar. T 47 unclip plastic cover carefully remove top seat belt anchor, removing carefully to not leave behind the two spacers; these should be secured with a captive speed nut. unwind captive nut,remove spacers, and place top belt assembly onto the hockey stick shaped down bar. stock bolt/seat belt NOTE IF BELT ANCHORS ARE VERY HARD TO REMOVE USE LIGHT HEAT TO SOFTEN LOCKTITE ON BOLT. Using top bolt as a guide, install top belt/washer/down bar/two spacers/speed nut and install into upper b pillar do not torque down. install lower belt connection. first make sure the rod end is adjusted so the new lower belt slips easily into the anchor and threads without any tension on it from the down bar. adjust rod end as needed. then assemble onto bolt: belt assembly/rod end/spacer and thread into lower mount. repeat other side. assemble bar onto down bars. rotate end for end and on itself to line it up properly. If you have to force it you have not got it lined up correctly. belt guides face up. snug bolts easily each side. torque bolts. done. its seams easy enough just didn't want to miss anything |
Gloria forwarded your email yesterday I did not read it until just now. F
FIFY |
Originally Posted by Omiotek
(Post 7078886)
not good pics but heres mine
its destroyed.
(Post 7078699)
OTTP makes a Harness bar?
mine rubs my driver side door panel tho:thumbsdow
Originally Posted by royce777
(Post 7079201)
(Post 7079229)
space it out. I adjusted the jig to make the fit more precise; did you buy it new from me?
(Post 7078828)
Cellphone quality :thumbsdow
Originally Posted by Smithkid21
(Post 7079413)
Give me your seats! :lol:
