ok technical question on the cluster
Old Jul 30, 2008 | 09:09 PM
rrutter81's Avatar
Any way i can keep the lights ON 100% of the time on my Instrument gauge WITHOUT covering up the sensor?
Im on the last step of my cluster experiment which i will post pics and a HOW-TO (if people want) to see what im doing.
Old Jul 30, 2008 | 09:11 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Correct. Just move it to lights-on.
Old Jul 30, 2008 | 09:14 PM
rrutter81's Avatar
elaborate? u mean my headlights? im looking more in to....
using a resistor on a specific wire that tells the cluster to turn off or on
Old Jul 30, 2008 | 09:15 PM
outtamymind's Avatar
turn your fog lights on, it illuminates your cluster lights
silentd's Avatar
move it to either headlights on, or running lights, or even the fogs will cause the dash lights to come on
lewisb13's Avatar
Yes sir. Just turn your headlights all the way on and all the interior lights will be on too. You can verify this by using the dimmer switch after turning them on. Dude, you wanna build something nuclear? Between you and I we have got the engineering on lock down.
Old Jul 30, 2008 | 09:32 PM
rrutter81's Avatar
gah i really want this to do specifically with the cluster if im going to offer this to css.net
ill give u guys a hint here.... but its much better when im done....
im looking to TINT the cluster cover with 20% tint... and i have bright enough LEDS to shine BRIGHTLY through.... however i dont want to fiddle with these damn fog light stuff.
It also looks hyperwhite (not blue tint) and was all done for under 10 bucks.
actually im going to be installing my intake manifold coolant chiller within the next month. Very cheap method of doing it and i posted a blurb about it but no1 answered, so im using it. Also it doesnt cost more than 100.00 to drop IAT2s 30+ degrees... guestimating.... i will have an HPTuners log (before and after)when i do show it.
back to the question!
which wire signals the cluster to turn on... i really dont want to break out my voltmeter
Old Jul 30, 2008 | 09:33 PM
ls1fbody's Avatar
Haz l33t wheelz.
my headligths turn on when i turn on my windshield wipers, but if it's too bright out, the gauge lights don't come on. same when i turn on the fogs. my instruments are completely independent of anything but the sensor.
Old Jul 30, 2008 | 09:36 PM
ls1 your dash will light up when you turn your fogs on just during the days its hard to tell.
Old Jul 30, 2008 | 10:11 PM
rrutter81's Avatar
obviously ill have to do this the hard way
Old Jul 30, 2008 | 10:13 PM
ItalianJoe1's Avatar
There is a little known GM reflash for keeping the cluster backlights on all the time.
It was created due to some complaints about not being easy to read, they reflash the BCM and it keeps the lights on the cluster on always, without using any other dumb trick or having to do custom wiring.
Old Jul 30, 2008 | 10:28 PM
rrutter81's Avatar
ooOOOooOOOooo
hptuners can do this?
i checked hptuners on several tabs and couldnt find it, so im assuming it is a GM specific reflash
Old Jul 30, 2008 | 10:30 PM
Originally Posted by rrutter81
ooOOOooOOOooo
No HPT. You need access to GM Dealerworld and the Tech 2 flash stuff, you have to flash the BCM, not the PCM, so its not something aftermarket.
Old Jul 30, 2008 | 10:34 PM
rrutter81's Avatar
good option... hmm i dunno
On a side-note, does anyone know a way to remove the chrome strip without damaging the needle on the speedo, rpm and fuel gauge?
Old Aug 3, 2008 | 02:09 PM
smp4488's Avatar
When are we going to get to see some pics of this madness?
06MetallicBalt
Jul 20, 2025 08:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
jmelton327
Sep 26, 2015 10:04 PM
