A pillar pod
Old Nov 30, 2010 | 05:57 PM
AyrtonSenna's Avatar
A pillar pod
Hi all,
I am buying the A pillar triple gauge pod from zzp, but I would need to know if I can fit the AEM gauges in all 3 of them, even in the one where the stock gauge is meant to be.
Does anyone of you know? Thank you
Old Nov 30, 2010 | 06:19 PM
iboost's Avatar
they fit kinda sorta as you can see...its realllllllll snug and if you use the bezels they will scrap into the pillar...
Old Nov 30, 2010 | 06:38 PM
but they still look good!! Thanx for the pic dude!! The best thing I could expect is to actually see how they look like!! Thanks again
Old Nov 30, 2010 | 07:59 PM
tomj77's Avatar
i had to take the bezels off my defis as well. they fit tight which they are supposed to otherwise they can pop out. if its to tight, take a rotary tool and a sanding bit and sand around the inside of the hole a bit so it goes in a little better, but dont do it to much or ull have to use silicone to keep em in there
Old Nov 30, 2010 | 10:35 PM
iboost's Avatar
No problem man
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
