Plasti Dip Recommendations?
Old May 5, 2015 | 12:54 PM
E4Overlord's Avatar
SO! Because I jacked up my trunk I've settled on Plasti Dipping the Hood, Roof and Trunk. However...I'm at an impasse as to what color I should do -.-.
My Ideas: Midnight Blue, Deep Red, or a Metallic Grey/Space Grey color?
What are your thoughts on what would synergize well with Black? I'm just trying to get some suggestions.
Old May 5, 2015 | 12:55 PM
Olybaltss's Avatar
Copper, deep/dark blue, red?
Old May 5, 2015 | 12:56 PM
E4Overlord's Avatar
OOOO! Copper! I'll look at that
Old May 5, 2015 | 01:55 PM
Dipped_Cobalt's Avatar
your car is already black
do the trunk matte black
done.
Old May 5, 2015 | 02:00 PM
E4Overlord's Avatar
done.
But...but...I wanna do the GT Stripes on the Fenders and do a couple up the hood to the trunk Matte Black on Black would look decent you think?
Old May 5, 2015 | 02:09 PM
tuned08ss's Avatar
I don't imagine this would come out nice with plasti dip.
Old May 5, 2015 | 02:11 PM
E4Overlord's Avatar
I'm not confident but a matte black trunk with GT Fender Stripes and Hood Stripes would look better than a scratched up Gloss black Trunk with Touch Up paint and Bondo sticking up haha.
Old May 5, 2015 | 02:17 PM
i don't imagine this would come out nice with plasti dip.
pay a visit to dipyourcar.com and see..before you speak. Its crazy options.
Old May 5, 2015 | 02:20 PM
no_ss's Avatar
Save yourself trouble and get that all wrapped if you're serious. And do vinyl fender stripes.
Old May 5, 2015 | 02:27 PM
E4Overlord's Avatar
I'll have to find a place that can do that and get some quotes. I forgot about wrapping.
Old May 5, 2015 | 02:32 PM
E4Overlord's Avatar
Looks like it's going to be $200-225 to Wrap the Trunk and do the GT Stripes Matte Black. Not horrible..but for 75 more I could grab a trunk haha.
Old May 5, 2015 | 02:33 PM
I don't think you can wash wrap.
if you can spray can..you can dip it.
Last edited by Dipped_Cobalt; May 5, 2015 at 02:33 PM. Reason: Automerged Doublepost
Old May 5, 2015 | 02:45 PM
E4Overlord's Avatar
I'd be retarded if I screwed up Plasti Dip eh? Easy stuff or is there a "sand down, primer, fancy paint gun, spray" kinda thing
I only say that because the Pro Kit on dipyourcar is 225.00
Old May 5, 2015 | 02:52 PM
UnkleRaRa's Avatar
You'll be good with a couple cans.... no prep, just clean dirt and debris off.
If matte black looks good, eventually you should think of painting it, or you will have to re-do the dip every so often.
Old May 5, 2015 | 02:56 PM
you can get a kit if you want (I did)
but I say get 4-5 cans.
remove trunk
set it up so you can spray in front of you. no weird angles
clean it make sure no moisture anywhere dirt/debri/grime
sand down those bondo job you did to an even surface
spray away. let dry, do like 5-6 coats.
Old May 5, 2015 | 03:02 PM
Twoozofjuice's Avatar
cans will absolutely not come out as smooth as spraying with a gun. Dip gets a bad name because people don't know how to spray it and **** it up them blame the dip. Cans don't spray the same amount as spraying out of a gun so you don't get enough coverage and it doesn't peel as well. Also you will more than likely get tiger stripes with cans. Get a gun, practice with it and you'll get much better results
Old May 5, 2015 | 03:10 PM
double clutch's Avatar
Just get it wrapped. Its not worth buying a dyc gun if your only going to do a couple of panels one time. Unless your like me or twoozofjuice and change color all the time, its not worth it.
Old May 5, 2015 | 03:15 PM
E4Overlord's Avatar
Yeah I understand that. Wrapping is just A LOT more than even having it professionally dipped :/ $150 to Debadge the Trunk, Dip the Trunk, do the Fender Stripes all Matte Black Dip. or that $225 for Vinyl Wrapping the Trunk and doing the Stripes. Money is somewhat tight, I made a mistake so I'm trying to fix it in the most cost effective way :/
Old May 5, 2015 | 03:46 PM
heeter_33's Avatar
Don't put lipstick on a pig. Fix it properly first (unless you've already done that) then just whatever you want.
Old May 5, 2015 | 04:02 PM
I would get it dipped correctly
I got the gun so I have no problems loading it with dip and spraying away.
Speaking of colors...I made a new color the other day and it's pretty sweet. In pics it almost looks like a raspberry with flake and such in it but in person it's got a purple hue to it and has a galaxy type look. Will be spraying it tomorrow to see how it looks over a light base.
Old May 5, 2015 | 04:03 PM
post pics.
I should be redipping my car this weeeked.
Old May 5, 2015 | 04:05 PM
post pics.
Where do you dip your car? What color is it right now?
Old May 5, 2015 | 04:10 PM
at my bros house in his carport.
its matte black right now, but in need of a respray
I want to redip it balck, then add the new top clear coat with some dipcoat....naptha bathe after.
Old May 5, 2015 | 04:14 PM
Im still deciding on what pearl i want next. Ive got a solid 6-7 coats of white right now so i just need a couple gallons of the new pearl top coat they just came out with
