powder coating sc?
Old Dec 17, 2008 | 06:56 PM
bluechevycobaltss's Avatar
powder coating sc?
Has any powder coated their sc? I've seen some people spray paint them but never really seen anyone powder coat them. Is it even possible to get it powder coated or will it mess something up?
Old Dec 17, 2008 | 06:58 PM
TurboTechRacing's Avatar
As long as everything is removed out of the SC, and you mask all the places the coating should not cover you should be fine. The 400 degree baking should not effect the aluminum, it should not cause it to warp/change in structure.
Old Dec 17, 2008 | 07:11 PM
Would getting the powder coat on the inside of the sc cause any damage? if you drain the oil from the snout (i think thats what they call it) could you powder coat that to? are the holes where the rotors on the inside the only parts to really worry about making sure they dont get powder coat in them? sorry for all the questions but i think it would hold up better then spray paint. Thanks for the help
Old Dec 17, 2008 | 07:13 PM
Yes I am sure it would, that is why you would remove the "guts", mask the holes, and coat... That way no coating would be inside the SC.
Old Dec 17, 2008 | 07:27 PM
got ya ill have to talk to the guy i know that does it and see what he can do thanks for the info
Old Dec 17, 2008 | 08:37 PM
No problem.
Old Dec 18, 2008 | 05:32 PM
mcphatty's Avatar
you may as well wrap a wool blanket around your S/C too.
paint your supercharger if you want to go that route, but i would highly recommend against powdercoating it.
Fearedbynone
Apr 14, 2016 03:25 AM
Jan 12, 2016 12:01 AM
hawkssoccer11
Sep 30, 2015 12:14 PM
Sep 27, 2015 08:53 PM
