Powell harness bar
depending on the seat belt top anchor plastic cover (they vary in size) this plastic cover can bind on the belt and stop the belt from retracting easily so you may need to space it out with a simple washer; ...send me an email I can send details to you...
eric I emailed uou pictures, the washer you need should be about 15 mm iirc, but can be a 7/16 i.d flat washer no problem, you wont see it behind the anchor, and then the belt wont rub. There is lots of thread in the top anchor bolt so all good. I think also the bbreak forming of the blade in the down bar can vary slightly, the last two installs I had no problem with rubbing but have seen it from time to time. all the best, let me know how it turns out....
yea i had same issue eric bought a set of washers you might need 2/3 and it works fine now but it did fray my seatbelt a bit tho lol used a lighter to get rid of most of that lol
