Problems with sunroof!
Old Jun 12, 2008 | 09:40 PM
2008CobaltLT's Avatar
Hey there,
So two weeks ago i purchased a 2008 Cobalt Lt and sence then i have been to the dealer 3 times concerning the sunroof. What is happening is when i close either the drivers door or passengers door the sunroof will jump about 1/4 of a inch. It was whisleing but i fixed that, now this is the next thing to fix. I was told it may be to air thight and the pressure would just come out through there but this to me sounds like a bigger problem may arrise. has anyone had any problems like this before and what have you had to do to fix this?
Thanks a lot,
Tyler Nesbitt
Old Jun 12, 2008 | 09:41 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
I wouldnt worry about it. Mine jumps a little I mean when you swing your door closed all that air has to go somewhere. Is it leaking when it rains?
Welcome to the site BTW
Old Jun 12, 2008 | 09:43 PM
OrngBalt's Avatar
yea.... thats pretty normal.
Old Jun 12, 2008 | 09:48 PM
chipmd's Avatar
Yup mine jumps when you close the door too, does that all the time. However have had it back 3 times for leaking.
Old Jun 12, 2008 | 09:50 PM
we havn't got a good rain sence i have owned it but it whisles when you get it up to 110kph i have got it ajusted a bit on my own and it seems to be a little tighter now but still, I didn't think it was some thing normal
Grimlakin's Avatar
mine works and does the jump too.
Old Jun 12, 2008 | 09:52 PM
Well thanks a lot for letting me know that mine isn't the only one. I thought maybe the dealer was screwing me around and what not , i will take a picture of it and let you guys see the problem
Old Jun 13, 2008 | 01:24 AM
TheCaptain's Avatar
If you don't have a sunroof, your door weatherstripping does the same, just you can't see it because you're usually not paying attention. The sunroof is the easiest place for compression to escape, so it budges the sunroof a bit. It shouldn't cause a problem, but it shouldn't whistle either.
Mine has been up to 260 Kph, and doesn't whistle.
Old Jun 13, 2008 | 10:20 PM
Apcsox's Avatar
yup, I believe all cobalts do that..... same as that annoying gap between the hood and front bumper
Old Jun 13, 2008 | 10:24 PM
coderocks's Avatar
I work for GM and have had a white 2007 ss with the 2.4 engine, The sun roof has a horrable noise when tilting it up, the slide back does not make any noise but the sunroof does jump when you close the door. it is as another said, just air trying to escape. i don't hear a whistle from it though even when it was broken but i have only driven it twice and it only got up to 65 MPH. my SS/SC does not have a sun roof because of to many problems with my old mazda i had. Coderocks.
Old Jun 13, 2008 | 11:21 PM
Stouffer's Avatar
There is an adjustment that can be done. There is a TSB for the 07's on this as well
Old Jul 7, 2010 | 10:20 PM
und1974's Avatar
Is there any maintenance that needs to be done to the sun roof? My '08 seems to be moving slowly, like it is binding. Should I use a small amount of oil such as WD40 or machine oil on the tracks? Just wondering.
Thanks
Old Jul 7, 2010 | 10:27 PM
chris88z24's Avatar
You drive a Chevy Cobalt, GM's economy car. It's not going to be perfect by any means.
Oh, the sunroof thing is normal.
Old Jul 8, 2010 | 09:58 AM
BLUE TRANSFORMER's Avatar
My switch cover fell off.The switch is broken and dangling. Where is the fuse for the sunroof? I know where the fuse panel is at. Just can't locate the fuse.
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
