quick front grille question
Old Feb 2, 2010 | 11:29 AM
averagewhiteboy's Avatar
Hey guys,
Probably gonna order the t/c grilles from CED here this week.. My question is this:
Can you do the grille swap while keeping the bumper on the car? It seems like the bottom one just kinda snaps into place (from how my stock bottom grille was).. Does the top basically clip in or is there a few tabs and stuff? Can't quite figure it out from the image from their site.. Looking to do it with the bumper on the car. I figure I can do the under-side of the top grille by reaching through the bottom grille opening..
Images or links to help? Thanks!
Link from CED site:
http://www.crateenginedepot.com/stor...P2238C399.aspx
Old Feb 2, 2010 | 12:02 PM
NCC-2000's Avatar
It's pretty easy to do, you just remove all the pushpin clip things holding everything together, you'll understand better when you see it.
Old Feb 2, 2010 | 12:03 PM
kissrocker52's Avatar
how did you remove the bottom grille cause i have the horizontal grille and i cannot get it out and i dont want to break it
Old Feb 2, 2010 | 12:06 PM
roser4888's Avatar
its pretty easy just clips in no hardware needed the one you will order just pushes in
Old Feb 2, 2010 | 12:11 PM
The easiest way to remove the bottom grille is to hit into a snow bank. It'll pop right out. lol. That's what happened to me last year.. lol
But it's an easy procedure to swap with the bumper on the car?
Old Feb 2, 2010 | 12:19 PM
ok ill try but i just dont want to break it
Old Feb 2, 2010 | 12:21 PM
09blackonblack's Avatar
yes it can be done in the car.
Old Feb 2, 2010 | 12:34 PM
wardzach2007's Avatar
QFT
Took me about 30 minutes. I also replaced all the rivets with screw in rivets to make it easier on me.
Old Feb 2, 2010 | 01:07 PM
DaBuzzard's Avatar
And I thought I was the only one using the snow plow method of grill removal
Lower is a 5 minute job, upper is a little longer but not too bad as long as you don't have Popeye arms
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
