Quick HID Question
Old Jun 28, 2010 | 10:35 PM
BPark86's Avatar
Quick HID Question
For some reason after it rained about a week ago my driver's side 6000k stopped working. I bought a new ballast and cross checked it, and the bulb, with the passenger side hookup (that side still works without a problem) to make sure that the new ballast and the bulb were not faulty. The driver's side connector seems to not even be sending power to the ballast since it is not making sound but it will still power the leds and hi-beams in my gen 2 projectors. The light will not flicker or flash at all, it never comes on. I am making a huge road trip in a couple of days and need to find a temporary solution. Is this because I don't have a relay? Even without it it seems like it should flicker - even when that light is the only one hooked up it still won't turn on so I don't think that the relay is an issue. Please let me know what you think!
Old Jun 28, 2010 | 10:51 PM
kidcrash603's Avatar
The connectors probably got water in them, or the ballast did. Take everything apart and check for corrosion. Whichever is affected needs to be replaced.
Old Jun 28, 2010 | 10:56 PM
BPark86's Avatar
No man, like I said, I cross checked the entire assembly on the passenger side and it works just fine. I even cleaned the contacts. The driver's side powers everything but the ballast evidently since the HID won't turn on. All of the other three HID kits still work no problem. Any other ideas?
Old Jun 28, 2010 | 11:24 PM
Ok, so you just made my point... the connectors got wet and have corrosion INSIDE them... I understand that you cleaned the contacts but you can't clean inside the plastic where the corrosion will be.
You said ballast and light works on the passenger side, so that leaves only the wiring as the problem.... connectors are the most common failure.
PM Mkulrey13 or send a message through www.buyhids.com and get some relays. We've got them for cheap and it will help prevent this in the future.
Old Jun 28, 2010 | 11:37 PM
BPark86's Avatar
I see what you're saying - I thought you meant the HID connectors. So you think the stock wiring harness 5-prong connector is messing up even if it will power the hibeams and leds? Your relay would fix that problem? I'd need one for both sides, right? Sorry for all the questions but I need to fix this fast. I appreciate the help!
Old Jun 29, 2010 | 12:00 AM
Yes
Yes
and yes.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
