quick question on hids
Old Jun 22, 2012 | 06:32 PM
06cobalt racer's Avatar
today i was installing my new hid fog lights. i took out the headlights to gain access. when i was all done i tested everything to make sure it was all working. well everything works except for the drivers side headlight Hid. it was working fine before i took them out, i checked all the wiring and it seemed fine. i am thinking it is the ballast that went out on it. i can hear the passenger side ballast humming but there is no sound at all coming from the drivers side.
thoughts?
Old Jun 23, 2012 | 11:58 AM
Old Jun 23, 2012 | 11:59 AM
BlackARCA06's Avatar
Prolly the ballast or bad conncetion, Ive had a bad connector before. Only thing I can say is take one of your other ballast and hook it up to the drivers side and see what happens.
Old Jun 23, 2012 | 12:03 PM
CordiaDOHC's Avatar
Originally Posted by blackarca06
prolly the ballast or bad conncetion, ive had a bad connector before. Only thing i can say is take one of your other ballast and hook it up to the drivers side and see what happens.
+1
Old Jun 23, 2012 | 05:52 PM
yeah i will mess with it, look over everything real good and then swap the ballast
Old Jun 23, 2012 | 05:55 PM
juan1101's Avatar
check the fuse for the driver side low beam that happend to me once i thought it was the bulb so i tried another hid bulb i had and nothing then i check the fuse and it was burnt out
Old Jun 23, 2012 | 06:00 PM
fuses are good. i checked those when i noticed the problem
Old Jun 23, 2012 | 06:16 PM
Wert842's Avatar
Could be what I did once, I forgot to plug the whole headlight harness adapter in... Ya stupid me.
Old Jun 27, 2012 | 09:54 PM
found the problem!!! one of the wires got pulled out of the big blue connector! very easy fix and now i have both headlights working!!!!
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
