removing center console
Old Oct 26, 2007 | 06:24 PM
JDMjunkie's Avatar
okay how do you remove the center console? i want to install my short shifter tomorrow but it doesnt tell you how to remove it..is it screwed in or held by clips? i dont wanna break anything..ive only had the car for like 5 days lol.
Old Oct 26, 2007 | 06:42 PM
thedub784's Avatar
i believe clips...
Old Oct 26, 2007 | 06:47 PM
Cobalt30's Avatar
pull the plastic center cover up first which has the whole cut out for the e-brake. that one over lays the center counsel where your shifter is. so just pull that one up first then just go straight for your plastic around your shifter and just give that a good pull straight up.
also fyi be careful cause the cig lights do have wires running to them so if u pull it off to fast or just to far away from it u might break either the wires or the 12v sources them selves.
and yes. just clips man
Old Oct 27, 2007 | 11:04 PM
NP05Cobalt's Avatar
^x2 couldn't explain it better... and the cig lights i learned the hard way so make sure that you dont pull too hard
Old Oct 28, 2007 | 03:44 PM
spiderbite's Avatar
i made a how to for removing the console...
https://www.cobaltss.net/forums/how-guide-43/how-remove-center-console-%5B56k-%5D-81949/
not sure if it's the same for a 5-speed though
Solaris99
28
Mar 15, 2017 01:22 PM
nathan112i
Sep 30, 2015 07:12 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
metroplex
Sep 27, 2015 07:48 AM
