removing interior?
Old Mar 8, 2011 | 11:34 PM
AzraelRaezier's Avatar
removing interior?
okay so ive looked for a thread on how to remove like door panels and **** but i for the life of me cannot find one. does anyone have pics or know the process in removing these? im going to be painting my interior and want to take the pieces off the car to do this. i have a friendw ho knows how to get the back pieces out. but as far as the door itself. i cant find how to get the panels out.
if i posted this thread under the wrong section. i apologize in advance for all you haters that get all **** for threads in the wrong place
Old Mar 9, 2011 | 12:36 AM
myfakeevo's Avatar
what do you mean paint your interior? like your roof liner? im not sure what your trying to paint to justify taking off door panels
Old Mar 9, 2011 | 12:55 AM
cmatthewb101's Avatar
....pull. The interior is basially like playing with legos.
Old Mar 9, 2011 | 06:28 AM
its def mega blocks not expensive enough to be legos
Old Mar 9, 2011 | 06:32 AM
Touche
Old Mar 9, 2011 | 06:49 AM
1995chevy's Avatar
just did this yesterday ( broke the arm rest warrenty replacement sweet) i would have took pics if i saw this post okay things you small flat head screw driver and philips i believe and a panel remover looks like a crow bar okay start by taking the flat head and there is a lil tab in the armrest like a dished out piece you will see like a battery tab press on that tab and pull out the piece like a battery cover there is one in the door handle area too use a flash light upper left hand corner bingo the you will see a screw in there and 2 in the arm rest remove then take out were the door controls and mirror thing is out there will be a bunch of connectors on the drivers side then with pry bar go along the door and get under the panel search to find the strong point becareful there are push tabs in the door that ill break easily or if its too cold us the pry bar to pull the push tabs out then after all is lose lift up and the weather striping will come lose then door is free
Old Mar 9, 2011 | 03:17 PM
Hammbones's Avatar
Wall of text hits you for 9098809820938450986 points of Damage.
Wall of text scores a devastating hit!
You are no more...
Old Mar 9, 2011 | 09:46 PM
basically im removing all the plastic interior pieces from the doors back. leaving the fabric alone. but i need to pull the plastic door panels OFF the doors to paint them with the scheme i want to do. dont wanna **** with having them on the car and taping my whole car off. im going with a black n white theme for my car. yes i know whites going to be a bitch to keep clean but ill be fine. my dash is black, glove box is black, piece unders steering wheel is black. but all the other interior plastics.... Tan... and i dont like it. so im redoing it to my taste. seen a guy at a meet who had his painted and it looked hella sick. he had a black n gold theme going on.
Old Mar 10, 2011 | 09:14 AM
xxxxsh4d0wxxxx's Avatar
Wall of text's hit is critical!
You have been defeated by wall of text.
Fixed.
Old Mar 10, 2011 | 09:22 AM
outtamymind's Avatar
there's 3 screws, unscrew them and pull from the bottom and work your way up, the first one takes a bit of a tug
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
Sep 27, 2015 08:53 PM
