Removing tail lights?
Old Aug 5, 2007 | 01:18 PM
Xavipheus's Avatar
So yeah today I wanna nightshade my tails but i cant figure out how they come out, or how ill get to the top center one. Anyone wanna care to explain to me please?
Old Aug 5, 2007 | 02:23 PM
2006BlackSS/SC's Avatar
outer and inners take carpet off remove the bolt's your set for the 3rd brake light remove upper trunk lining remove bolts there you go
Old Aug 5, 2007 | 02:54 PM
Red07SSNA's Avatar
Your owner's manual tells you how to get to the back of the lights including the center brake light. Once you get that far there are two nuts on each of the 4 light assemblies (coupe) and then you have to remove the light bulb wiring and then compress 2 plastic retainers and then just pull the light fixtures out. they are sealed with some foam type gaskets.
Old Aug 5, 2007 | 03:14 PM
Xavipheus's Avatar
wrong. The inners dont even have bolts
Old Aug 5, 2007 | 11:23 PM
i mis typed it is all xav
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
