Shaved key hole!
Shaved key hole!
Ok guys, i wanna see your shaved key hole on trunk! Also i wanna knw how or where you got it done at and how much it cost! I also wanna see what yall did to your door key holes?
some people would use that whole search thing. for those that it proves to difficult, you become an annoyance. just for ***** ill do that super hard thing for you
https://www.cobaltss.net/forums/show...haved+key+hole
found on the first page of searching "shaved key hole"
heres mine in a thread i made:
https://www.cobaltss.net/forums/appearance-48/trunk-lock-shaved-163638/
If you need a howto then you shouldnt even be considering this yourself.Also I wouldnt recommend just slapping some bondo over the hole and smoothing it,I would make a sheetmetal filler and weld it in grind down the welds use a very minimal amount of fiberglass and smooth it,paint it done.If you use just bondo it WILL crack over time especially if you plan to run a system in that trunk EVER. Im not trying to be an ******* just making sure you dont attempt this without the proper knowledge and tools.
